I've built a little Single Ended guitar amp. Pretty simple thing; one 6BQ5 for the output, with one 12AX7 as a driver. Given the two triodes of the 12AX, I actually have what I guess you'd call a 'series' driver, as the first section is feeding the section which drives the output tube. This is basically a 'spare parts' piece, with a little SE output transformer I pulled from an old 'Hi-Fi' amp made by 'US Audio'. I actually believe this to be an Asian company using the name of 'US Audio' as a USA Marketing ploy. None the less, it came to me with only one good OPT, so I swapped them both out and had this as surplus. I also had an old OPT that I was able to get a HV of about 250V out of after setting up the output section. I don't recall all the details, but I've got a 150K resistor with 100uf / 100V bypass cap, and as I recall I think the bias calculated out to be around 35ma on the output tube. So, moving on to the 12AX, I think I'm running around 120VDC or so on the plates of both triode sections. As, as per what I consider 'typical' Guitar amp 12AX cathode set-up, there's a 1.5K resistor to ground on each triode cathode, along with a 25uf/25V bypass cap.
So, now comes the question: Can I change the values of the cathode resistors on the 12AX section in order to 'adjust' the gain going to the output tube?.....and, if so, is 'more' resistance equal to 'less' gain? I guess I'm just thinking about output tubes here....where increasing a cathode resistor value would result in less current draw by the output tube....and reduce output power......or so I believe. I may be wrong....and if so, PLEASE correct me. Anyway...as my amp stands now, using the 12AX as the 'driver' tube.....it's just too 'gainy'! I've played around with other tubes, including a 12AT, a 12AY, a 12AV, and a 12AU. I found this substitution to be very revealing, as the 12AX provided way too much early gain, where the 12AU on the other end of the scale provided just enough gain to drive the amp to a very minimal distortion level. The AT and AY seem to be the sweet-spot for the amp.....but I'm simply wondering if I can go back to the 12AX and tame the amp through the circuit vs changing tubes? Perhaps the answer is to drop the voltage to the plates? Just looking for some advice here from someone who's maybe played around with this and has some experience with these kinds of issues.
Many thanks,
Tom D.
Many thanks,
Tom D.
