ranukic
I found these crimp style male spade connectors at my local electronics supplier.
1. I used a sheetrock knife and pressed through the plastic on one side and then the other. I first tried cutting it all the way around but later found this to make a nice clean cut.
2. Next I used a tin snips to cut the spade down to about 1/4" wide.
3. Next I used the sheetrock knife to spread the remaining spade to assure connection on both sides within the Pioneer terminal.
Check out the pictures and I hope it helps someone out.
