The company I work with,
Elecraft, is a small ham radio company using Digital Signal Processing engines for much of the goings on inside these days. As a result, all of our contemporary products are loaded end-to-end with surface mount. Each generation of products contain the next smaller generation of SMD devices.
All of us run around with magnifiers on our heads and use lots of light at the work stations. Fortunately, we have hired and trained some younger techs who can do the work far better than us old-school dudes. I let 'em, too.
We also sell full kits where you purchase the radio and stuff the boards with thru-hole, leaded devices. We've been offering the same kits continuously for the past 20 years at that. The kits result in a high performance ham radio _but_ the sustaining engineering to keep the kits going are quickly swamping out any margin in the products. That is, we get daily notices from the component manufacturers that this or that part is becoming No Longer Available.
This started with the chips that went to SMD packaging only. We responded with little adapter boards to adapt the SMD device to the holes where a DIP socket once was installed. We're now encountering it with odd-ball value resistors, diodes and capacitors with unique RF characteristics.
While we're able to offer these old-school, Heathkit-style kits for a while longer, there's the Day of Reconing where they'll no longer be worth carrying because the old-dudes who want to have the build-it-yourself experience will be too old to handle the parts.
The cost to tool up for SMD rework is far higher than that little Weller soldering iron and a roll of 60/40 solder. Forget solder braid or a solder sucker, too. Its a different world.
Cheers,
David
