I tried to search the turntable forum, and got some weird ad in response.
Anyway, I've lost one channel in an arm that was supposedly rewired before my purchase. I've never been into a 3009 before, and wondered what might make this 'arm different doing a re-wire.
Don't lose any of the screws, they ain't american and they ain't metric. Some odd british size and I had to order em from...france.
And Garrards. I ordered a small baggy of them from a seller on eBay in Australia.The screws used are known as BA,which stands for British Association.This is a very old type,and was commonly used by precision instrument manufacturers and model railroad enthusiasts. They are available,but not easily!
^^ You don't need that. it's ridiculous money anyway. If push comes to shove you can refurbish the connector.
I lost you buddy. What do you mean DIN? Are you referring to the SME stock terminal? It's British. It can't be DIN. Wars have fought over this. What's instead of it anyway? So I figure this is a detachable headshell SME 3009 - and you connect a different none SME headshell to the TA? You can measure the mV's coming out of the TT from the RCA sockets. It will tell you exactly if sound is emanating or not. Any pictures to sort this out for me?
Most likely the spring loaded pins in the headshell are broken, you will need a new collar.
http://www.ebay.com/itm/SME-3009-S2...819309?hash=item3608cbf92d:g:rXUAAOSwMgdX0aAL
The pins are held in the collar with a type of Bakelite material which once cracked is almost impossible to fix. I have rewired and repaired dozens of the 3009 arms, not for everyone but not that hard, after a couple of dozen.
