Hi folks. I picked up a Marantz 2330 a while back, untested. It smoked from both channels so I put it away for a while. I paid Noah Schumacher to restore it but he never did. I dug it out and opened it up yesterday. It has clearly had someone in it--one of the power supply heat-sinked transistors was replaced with an NTE.
Both amp boards are FRIED. I mean, we're talking 10-12 resistors per board, ranging from dark brown to actually burned up. Wow!
So I have the service manual from hifiengine, and I can puzzle out the resistor IDs. The manual claims most of the resistors are 1/4W. Is that true? Is there any harm in replacing them with 1/2W? Also, the manual says each board has a 1k and a 2k trimmer. Any suggestions on which ones to use?
I plan to replace all the capacitors and transistors on each board with modern equivalents, as well as all the outputs and the trimmers.
I did try it with both amp boards unplugged and it comes out of protection just fine and lights up.
