rulerboyz
AK Member
Smoking resistor (solved)
I almost had my Kenwood KR-4140 fixed until I ran into another problem on the left side of the amplifier section. There is a 33 Ohm resistor located next to the output resistors that smokes when I turn the unit on. I know that the bias is high on that side, yet I don't want to leave it on long enough to try to turn the bias pot because that resistor will burn up if the receiver is on longer than 10 seconds.
I spotted a 1uf 50v capacitor on that same side that had a gob of solder that had fallen on it and was connecting it to a neighbouring resistor. I removed the cap and cleaned of that solder of and tested the cap which was fine, then put it back in. I turned it back on for a second, long enough to see that the smoking problem was still there. I just put a new 33 ohm resistor in and don't feel like burning it up as well. Anyone have any ideas where the trouble could be? All the transistors appear to be fine.
Also, this unit has two diodes on either side near the output resistors. On the circuit board each of these two diodes is labelled as though it represented 2 different diodes in series. 1 and 3 on one side, and 2 and 4 on the other. The diode test reveals a value of 1.5V or so which seems like an odd value for a diode.
