"Product Description
Instructions
1. Package delivery Sanger different adapters, you can eat the D01 end of the line adapter to the source, or DAC, the other end of the coaxial links, you can not apply a coaxial adapter to link the increase
2. D01 use to pay attention to the direction of the input and output signals required flow in the direction of the arrow, audio termination IN, after termination OUT, otherwise it will not sound normal.
3. D01 can be used in addition to coaxial digital signal (RCA, BNC), the clock signal can also be used in addition can also try to use it on RCA analog signals, video enthusiasts can put it in series used to improve the quality of video output AV or component video signal.
4. D01 has two switch three positions, respectively corresponding to three slightly different sound style
Users can choose their favorite sound style used either to train your ears to distinguish between them by switching capability.
When A file, B1 and B2 switch no role in the B file, B1 and B2 corresponding to different styles. (Ie B1, B2 gear must use when B, three styles are A, B1, B2)"
Package
1 x D01 Unit
1 x User Manual
1 x RCA male to RCA male Adapter
1 x RCA male to BNC male Adapter
1 x RCA male to BNC female Adapter
What more could one want, it will work on both analog and digital signals, but two would be needed for stereo. It does not appear to be an active device, so all of the internal components will be passive. Passive line compensation has been around for many decades. One common place was with the POTL (plain old telephone line, loading coils were used to counteract unwanted capacitance). Compensation is used in oscilloscope probes and the avoidance of impedance discontinuities and loading in the transmission and measurement of signals is a science unto its self.
Without more detailed information, the actual functionality is not known. Applying compensation in whatever form to a signal without knowing what and if any deficiency exists may be s shot in the dark. I take no sides as to whether or not this device works as advertised.
