So I've been thinking . . .
Discussion in 'Turntables' started by chaz, Feb 12, 2018.
  1. chaz
    chaz AK Subscriber Subscriber
    956
    Ontario, Canada
    Seeing as one of the main jobs power steering fluid and automatic transmission fluid do, is maintain the seals in their respective systems it occurred to me that the suspension in old styli which may have hardened might benefit from a drop or two of one or both of these.
    Before I go ahead try it out anyone here have any direct, or indirect experience with using this stuff for this purpose?
    Even if you don't whadya think? To crazy/reckless to be worth trying?
    Crazy like a fox give it a whirl?
  2. Lavane
    7,735
    northern cal.
    It all depends on what the seal is made of. The wrong thing applied and it could soften too much, dissolve, soften then reharden after what was applied dries out ect. If you use the wrong transmission fluid formula in a transmission it can destroy the seals. You will find type A, type F, ect. Working for an ag manufaturer for years I saw first hand wht the wrong fluid or oil can do to seals and gaskets.
    Vinylmasters likes this.
  3. Lavane
    7,735
    northern cal.
    Knowing what the cartridge suspension is made of would help. Im sure others hear would know the best thing to try.
  4. trainbuftony
    trainbuftony Electron Herder Subscriber
    You will never get the residue off of the inside of the cartridge, and it will attract dust and grime like a magnet.
    Vinylmasters and Lavane like this.
  5. chaz
    956
    Ontario, Canada
    Yeah that's the one thing that I got hung up on - the material used into the cantilever suspension. Probably not s lot of info readily available on that subject and given the tendencies manufacturers displayed with the other parts on their products chances are pretty good that there was very little standardization.
    As for the cartridge being contaminated with residue it's my understanding that most MM systems have the suspension housed in the stylus section rather than the cartridge. Is this incorrect?
  6. mprince
    mprince AK Subscriber Subscriber
    1,681
    Mooresville, NC
    Transmission fluid is full of detergents, no telling what they would do to the suspension materials. I'd look for a less aggressive lubricant.
  7. Djcoolray
    Djcoolray Addicted Member
    6,548
    A rocks throw from JBLM !!!!
    Transmission oil/power steering oil has too many nasty chemicals in it and should not come in contact with skin. Linseed oil from a longtime producer would be a good source and it would prevent the drying out of the cartridge suspension and is an oil...substance that evaporates into the air of a home and is healthy to those living in a home. Linseed flooring (and was used in many homes from the 1920’s through the sixties) has been found to release healthy vapors into the environment of a home that is beneficial to the occupants of the home. Automotive oils have chemicals that can contribute to the formation of ALS !!!
  8. 1tumbleweed
    1tumbleweed Kozmik Kowboy Subscriber
    6,125
    Colorado Front Range
    There is no "fluid" to keep in inside a cartridge, so the chemicals mentioned are not necessary or desirable.
    There have been discussions of using WD-40 (or, my favorite, Rubber Rejuvenator) to give the rubber elements in a stylus assembly (not the cartridge itself) renewed elasticity.
  9. chaz
    956
    Ontario, Canada
    you may be on to something there. I know that both glycerine and ammonia are good for restoring natural rubber, but again the issue of the exact material comes up - am I dealing with natural rubber? polyurethane 'rubber' or some other synthetic 'rubber'.
    I suspect that this is the reason for the general notion that hardened suspensions cannot be reconditioned. Not that it physically cannot be accomplished, but that the absence of knowing specifically what material the suspension in question is made of makes the possibility of success so remote as to be practically on impossible.
    I guess I'l keep searching for the specific types of material used by manufacturers in their suspension and see if I can come up with a short list.
    EDIT: My mistake folks. I realize that in my initial post I mistakenly wrote "it occurred to me that the suspension in old cartridges which may have hardened. . . ".
    It should have read "it occurred to me that the suspension in old Styli which may have hardened. . ."
    I have made the correction to the post. My apologies.
  10. chaz
    956
    Ontario, Canada
    I'd be very interested in reading more about these ideas. Do you have any links? Gonna spend the night googling it to see what has been done before. Don't like the sound of WD-40 much after reading what folks here written here about my initial idea, but the rejuvenator sounds interesting. My only experience with anything like that has been to restore the appearance of car interiors. Is what you mention the same kind of stuff or (hopefully) something more substantial than a surface treatment?
  11. 1tumbleweed
    6,125
    It's buried in a long thread titled "
    Possible Cure for Collapsed Stylus Suspension"
    in the "turntables" forum.
    Montycat likes this.
  12. Montycat
    Montycat AK Subscriber Subscriber
    17,588
    Vancouver
    guiller likes this.
  13. chaz
    956
    Ontario, Canada
    Thanks guys. Guess I've got some reading to do.
    guiller likes this.
