Hey folks - I'm in a bit of a pickle. My lingo may be off, but please bear with me. I heartily apologize if this isn't the proper forum for this or whatnot.
Growing up, I used to get vinyl records and play them on my parents' turntable. Since striking out on my on, I've been looking to snag a player of my own, since now I have records but nothing to play them on. I got an old Zenith record player/8-track player/radio (here is a terrible photograph I took with my cell phone) at an auction, assured that it had been tested and worked fine. Unfortunately, upon getting home, I discovered that the turntable itself refuses to spin - everything else seems to be fine, but the turntable platter stays put.
I've been fiddling all evening trying to find what the problem is - I've even opened the case up and tried to look for anything amiss. I'll try to explain what the problem seems to be as best i can - but like I said, my terminology may be incredibly off. Please bear with me.
From the motor there is this rod that extends, which, when the 'start' switch is turned on, touches the edge of this disc beneath the turntable platter, which then is supposed to turn it (?) which in turn spins the platter. I've got the motor running, and I can turn the platter manually (and thus make the disc beneath it move), but the motor is not making the disc move. The 'rod' touches the disc, but the disc will not spin. The disc is only moving when I manually push the turntable platter.
I hope that made sense. I am frustrated with this whole scenario. Could any of you give me any pointers? What could be the problem, and is there any way I can fix it?
Thanks for your patience. ^^
