some info on this pioneer speakers(see pic)
Discussion in 'General Audio Discussion' started by Metzu, Jul 12, 2018.
  1. Metzu
    Metzu Member
    61
    parlantes-colubna-pioneer-sd7-D_NQ_NP_820309-MLA27449262155_052018-F.jpg parlantes-colubna-pioneer-sd7-D_NQ_NP_641076-MLA27308870335_052018-F.jpg parlantes-colubna-pioneer-sd7-D_NQ_NP_958603-MLA27308992063_052018-F.jpg
    any info on this pioneers,how big are the woofers?
  2. orsen
    orsen just another old cheapskate that likes audio Subscriber
    8"
    from another site
    "Here's some info on these speakers. They are a good quality bass-reflex floorstander made chiefly for the Japanese market. The Pioneer speaker division by the late 80s, early 90s, had retreated from selling widely on global markets but was still producing excellent stuff (made in Japan) for the home market. Some of these speakers turned up occasionally outside of Japan -- mainly as demonstration models mainly at Pioneer stockists -- and I've seen them sell for between US$250 -- $400 on auction sites.
    They can handle ALOT of power -- up to 160 watts RMS and your amp should be a minimum of 40 watts RMS.
    3-way, 3-speaker system with an 8" (20cm) woofer, a 3" (7.5cm) midrange, and a 2.5" (6.5 cm) cone tweeter.
    Good bottom end with a frequency response of 35hz -- 20khz.
    They are 6ohms with sensitivity of 88db/w.
    Dimensions are 800h x 270w x 320d and they weigh approx 12kg each.
    Sound: Excellent!"
    Metzu likes this.
  3. toxcrusadr
    toxcrusadr Omelette au Fromage Subscriber
    33,988
    Central Missouri
    6 ohms and 88 db...gonna need some current for them thangs.
  4. Metzu
    Metzu Member
    61
    what you mean?
  5. orsen
    he means
    6 ohms is going to need more power than 8 ohms
    and
    that 88db is not an efficient speaker
    they will need a good amp to make them sound their best
    slimecity and Metzu like this.
  6. Metzu
    Metzu Member
    61
    will you pass on,it even if it cheap?
  7. Dave_1962
    Dave_1962 Lunatic Member
    20,426
    Ontario, Canada
    Oh I'd pass. In fact you couldn't pay me to take them.
    Metzu and slimecity like this.
  8. goodolpg
    goodolpg Just an old fart trying to help.
    Based on what orsen posted above if you have enough power to run them (small receivers should use caution) then go for it.
    I don't know exactly how much power would be needed, depends on your room, your music choices, and volume levels desired.
    Metzu likes this.
  9. Metzu
    Metzu Member
    61
    its for a small bedroom...
  10. Bodyblue
    Bodyblue AK Subscriber Subscriber
    4,051
    CA
  11. musichal
    11,806
    Norman OK
    If orsen is correct on what they go for, and these are significantly less, then maybe I'd at least go listen and look.
  12. Metzu
    Metzu Member
    61
    what you mean whit these are significantly less?
  13. goodolpg
    If they really are "decent" and what orsen posted wasn't just flowery marketing, seems like a cheap Japan only speaker would be worth a listen if close by?
    Metzu and musichal like this.
  14. Bodyblue
    4,051
    CA
    They are not small bedroom speakers, they will take up a lot of space and will require a powerful amp to get decent sound from them. Unless they are $50 or under there has to be some better options.
    Metzu likes this.
  15. musichal
    11,806
    Norman OK
    The whole sentence begins with "if." If the speaker is worth a few hundred, and if the seller were asking a lot less, then they might be worth a look. If you don't like the way they sound, and if you have a market for them then you could profit and upgrade your speaker choices, or buy the baby new shoes. :)
    Metzu likes this.
  16. Metzu
    Metzu Member
    61
    thanks guys
    musichal likes this.
  17. toxcrusadr
    33,988
    Central Missouri
    I always chuckle when people report "These speakers can handle a LOT of power." What does that mean? It doesn't even tell you whether you get a lot of music for your gobs of power. It's like saying "This car can use a LOT of gas" or "This vacuum can pull a lot of amps!" Not really a selling point. :dunno:
  18. musichal
    11,806
    Norman OK
    And a sort of corollary to that, people looking for new speakers that will handle the power of a specific amp/receiver. Is sound a concern at all? Often doesn't read that way. More like, I've got all these extra watts I'm not using, seems to be the theory.
  19. toxcrusadr
    33,988
    Central Missouri
    There's very little understanding of anything other than 'watts'. Perpetuated by the fact that mass marketers spend a lot of ink on watts and not very much on sensitivity, load impedance, etc.
  20. imral3
    imral3 Super Member
    3,640
    Blackwood, New Jersey
    Luckily, I know what's watt! Each of my speakers is 125 watts and my amp is 100 watts per channel. So, I have 450 watts total!! :rflmao:
