Sony 5disk CDP sanity check...
Discussion in 'Digital Sources' started by knockbill, Feb 2, 2019.
  1. knockbill
    knockbill Addicted Member
    8,115
    SE PA
    I have a couple of these CDPs,,, one started skipping, so I opened it up and wiped the laser with a dry Q-tip,,, still skipped a bit, and started giving "no disk" errors.... I dropped the disk carrier out and cleaned the laser again with a little alcohol, dried it with Q-tip... reassembled and it works...
    Is that all there is to fixing the "no disk error" or am I missing something before I reassemble the case??
    Thanks....
  2. imral3
    imral3 Super Member
    3,636
    Blackwood, New Jersey
    :dunno:
    Hopefully someone with a better answer than mine will be along soon to help.
  3. Hajidub
    Hajidub Chihuahua/Pug = Chug Subscriber
    5,618
    Colorado Springs, CO
    Clean and lube the rails. 99.9% of the time it isn't a laser issue.
  4. knockbill
    8,115
    SE PA
    Thanks for the replies,,,
    I did clean the one metal rail while it was apart, and re-lubed the rack on the other side with thin white lithium... Then took it apart again to re-clean, after the 1st post... It plays thru most CDs, but skips on some,,, I cleaned those discs, no joy,,,, but other than one that is obviously scratched, they play in other CDPs...
  5. Drumolator
    Drumolator Super Member
    1,382
    Plaucheville, LA
    They do not last forever. Peace and goodwill.
  6. cpt_paranoia
    cpt_paranoia Super Member
    1,181
    IIRC, Dr Audio suggests using oil, not grease.
  7. knockbill
    8,115
    SE PA
    I can try oil, time I open it up,,, it had white lithium originally....
  8. knockbill
    8,115
    SE PA
    Thanks for the input,,, Dropped the transport, cleaned off the lithium grease and tried a drop of oil on the rail, no joy,, there's something more than mechanical wrong with it as it wont see a disc now... may be the disc locating optic, but I think it has an electronic problem...
