Sony HP-610A HELP!!!
GMAN1970
Does anyone know how the heck to get into this thing? No service manual to be found on here or anywhere else... Please help...1244407-sony-hp610a.jpg
Nice. I remember working on them.
The turntable is a Dual, right? If so, there should be 2 lock down screws that can be loosened. To remove the TT, tilt them outwards and they'll clear the holes in the plinth. Lift up on the TT while holding them out.
The electronics should have 4 feet with screws in them. Those screws will also secure the electronics in place. It should slide forward as a unit. IIRC, you have to remove the TT first to clear the electronics - its been 40+ years since I saw one so might be a bit foggy on that detail.
Cheers,
David
