SONY PS-313 FA Turntable Information Please
Discussion in 'Turntables' started by zeplin43, Feb 21, 2010.
  1. zeplin43
    zeplin43 Well-Known Member
    522
    Coimbra, Portugal
    I have the posibility of buying this Sony turntable.There is little or no information for it(not even VE) have any of you any experience with it.
  2. Sam Cogley
    30,618
    SW Missouri
    Depends on the price. Looks like a later cousin of the PS-Xxx series. If so, it should be pretty darned good.
  3. zeplin43
    522
    Coimbra, Portugal
    The asked price is 75$ do you guys think this is worth a shot?
    Did Sony make there own tables or are they rebadged TTs?
    Where can i get a Manual for this since the seller do not have one?
  4. thedelihaus
    thedelihaus Nocturnal transmissions
    29,301
    Boston Area, Massachusetts
    It's gonna be a good table but not a great table.
    It has seen the effects of cost-cutting- no quartz lock, no X-Tal lock, no VTA adjustment, more plastic than the earlier and beefier models.
    But being a direct drive model and not belt drive, it should have decent power.
    I dunno what TTs go for in Portugal, but this is a table I'd say is $35-$50 here in the states.
    Not bad.
  5. Sam Cogley
    30,618
    SW Missouri
    In answer to the other question, Sony designed and built their own stuff. One of the few that did - though they did trade some technology here and there. I believe the X'Tal lock system used on some of their tables was developed by Denon.
  6. hakaplan
    hakaplan Needs professional help
    10,704
    Philadelphia, PA
    I've never seen or heard of that model--I don't believe it was sold in the US. I don't think it's plastic. The arm housing is screwed to the base. If it were plastic it would just be all one molded piece. I'd definitely check it out. If it feels like it's decent quality and everything works properly, and it's priced right, I'd go for it.
    As an aside, responding to what thedelihaus said, even lacking quartz isn't enough to disqualify a tt. The PS-X20 was a full auto, quartz, piece of junk. I know--I bought one as a student. The lowliest p-mount Technics was better.
  7. zeplin43
    522
    Coimbra, Portugal
    Here is a google tranlation from German of the only info i could get.
    SONY PS-313 FA solid Hig End, Hi-Fi Turntable - full automatic.
    DIRECT DRIVE STEREO FULL AUTOMATIC TURNTABLE SYSTEM!
    quiet and powerful direct drive. The instrument dates from the late '70s and was once the most expensive and most of his time by Sony. Thanks to the electromagnetic control, it has a precise Drehelaufzahl as a quartz clock.
    Here are some extras:
    Repeat (repeat) function
    Schalplattengrosse Weller 30/25/17
    Drehezahlkontrolle with Leuchtstroboskop
    An extra Tonarmkopfhalter
    Fully operable with the lid closed
    Absolutely stable synchronous
    Extremely heavy platter
    Bulk Tonearm Cable
    Specifications:
    Color:
    Silver Metallic
    Aluminum Front
    Drive:
    Fully automatic
    Electronically controlled direct drive
    Motor: DC servo motor (brushless)
    Drive controller method: Pitch control
    Platter: Aluminum diecast 30cmØ
    Drehezahl: 33/45UpM fine adjustment ± 3
    45-rpm adapter
    Tonearm:
    Dynamic / Static balanced
    Headshell connector: universal SMS
    Previous S-tube tonearm
    with fine adjustable auxiliary Rocked
    Kardanaufhängung with 4Punkt-peak storage
    Hydraulic all supported Tonarmabsenkung
    Anti-Skating
    Cartridge / needle:
    Stereo magnetic cartridge
    Sony diamond (tapered)
    Fittingly Nadelauflagerdruck 2.0 g
    Frequency Response 10-30,000 Hz
    Dimensions (WxHxD)
    ca.450x385x135cm
    Rocked
    about 9 kg.
  8. Analog King
    Analog King Active Member
    129
    I just found one of these for $5 in a Japanese thrift store.
    Missing the cover and needs a new cartridge.
    Scroe!!
  9. zeplin43
    522
    Coimbra, Portugal
    This one was only around for a couple of months.Its ok but i had better options to spin my lps.
  10. Analog King
    129
    The one I got looks the same as the one pictured in the OG post except it doesn't have the repeat button and it is just PS 313.
    Can't grumble for $5.
  11. Abarth
    Abarth New Member
    8
    Rome - Italy
    Taking back to life this very old thread, because I own this Sony turntable for almost a week now, bought it in a local "vintage market" for 140€, and I need some help from AK experts.
    Overall it looks superb and works decently but there are some issues and maybe you could help me finding a solution:
    • The sound quality is quite poor with many pops, clicks and background noise even if I play a new vinyl I'm guessing it as to do with the original sony ND 134 G cartridge that is almost 40 years old. Could be a good a idea replace it with an Audio Technica AT95? (I listen mostly to hard rock and heavy metal stuff and don't want to spend too much money)
    • Sometimes the table doesn't keep the speed starting to spin very fast and the pitch control seems not to work to fix the situation, the only thing to do is switching off everything and start it again. This happened, let's say, twice in a week
    • The tonearm with many vinyls (not all), when moving to the beginning of the record and cueing down doesn't catch the beginning of the vinyl and falls down on the side
    Any advices on what to check\do would be very appreciated, I'm not an expert so start from basics :)
    The turntable is connected to a Technics SU-V4A amp and two Sony SS-H 3500 3-way speakers
  12. gr33nhorn
    gr33nhorn AK Subscriber Subscriber
    194
    Norwalk, CT
    1. generic styluses for that sony cartridge seem to be available in the 12 euro range. That would be cheaper than getting a new cart.
    2. usual problem with old turntables - some contact cleaner spray, like deoxit should fix that
    3. is your anti skate calibrated correctly? if its too much, then it might pull the tonearm out while it is dropping, and make it fall outside
    alternately, you might need to adjust the stylus drop point.
    http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/PS313FA/
    look at page 11 for directions
  13. Abarth
    Abarth New Member
    8
    Rome - Italy
    thank you very much for your quick reply!
    I'll try to replace the stylus and see if sound quality improves.
    That service manual is great! I'll try to adjust the stylus drop point as the anti skating is set correctly
    Thanks again!
  14. Allan. A
    Allan. A New Member
    28
    I also have one of these years ago bought second hand. I had the same speed problem and never get it fixed... It seems to be a problem for this model. My local repair told me it's was some drivers to the engine, and maybe the head who reads the speed (like a head in a cassette deck) which is placed underneath the platter. Maybe it will help cleaning it, maybe not..
    At least I have up mine, because it was running all to fast all the time and was getting to expensive to repair...
    Your other issue I can't give you an answer to
