Hi people,
Is there a service manual for my turntable Vega P 700, I think it is the same like Sony PS - X 45 . Visually thay are exactly the same. Need service manual because belt is broken And need to replace it.Thanks
Direct drive...
OK, then. Does it get stuck at a consistent spot? I ask because I have a PS-X70 that has that problem. If it gets stuck at "9 o'clock" it will also get stuck at 12, 6 , and 3 if that is where the platter rests after it stops. If I move it a bit past those positions, it spins fine. I haven't had a chance to really dig into it yet, but it sounds like I have my work cut out for me. I've been told it could be a bad motor pole, or bad hall effect sensor, or bad caps, or an adjustment that needs to be made.
I put my X70 project on hold for now.This reminds me of my PS-LX55II -- it seems to require a nudge when stopped, but not always. It seems like the dead spots are about 90 degrees apart. I theorized it was a matter of the motor design just having large areas of "dead centre". id you find out anything about this
