brinsmead
Sony PS-x75 Turntable. Removal of cam/coil holder 1-867-113-00 to allow arm lifter to operate freely, and to stop
Arm related issues such as the arm swinging wildly before setting down.
1…unsolder all coil termination wires
2…unsolder cartridge wiring
3…unscrew and lift head wiring shield cover over cartridge wiring.
4…unscrew PCB board position detection sensor. 1-601-927-00
5…unscrew shutter and remove 4-867-111-00 from coil holder x-4867-102-0
6…unscrew 2 x grub screws on the x-4867-102-0 M3 x 4 with suitable size Alan key
7….before removing the grub screws, mark with texta pen, the arm tube and coil holder (above) and try to use the same idents where the existing screws have touched the shaft.
8…. Remove coil holder.
9….remove 2 x brass mounting posts
10..Remove 2 x magnet assembly. ( Yoke 4-867-108 ) identify the marking as they are to be fitted as taken off. ( lift vertically as ferrite magnetism is strong)
11…Remove the surclip on the shaft.
12…Ease the coil holder/cam 4-867-113-00 from the shaft.
13..Gently with coil wires still attached place upside down to expose Sony Grease ……remove all old grease from bearing
14..REMOVE all Sony Grease from shaft.
15.. Use white grease such as MOLYKOTE on bearing surface and on lifter ident.
16..When refitting the shutter make sure its centralised in the housing
fatigue cracks in the cam radiating down from the bearing insert.jpg72.5 KB · Views: 95
Remove the surclip to to release the Cam:coil holder.jpg73.3 KB · Views: 84
