sony STR-GX10ES & STR-GX90ES side by side nudes
Discussion in 'Members' Systems' started by yotems, Mar 17, 2017.
  1. yotems
    yotems AK Subscriber Subscriber
    632
    enjoy
  2. yotems
    632
    gx90 serial number
    gx10 serial number
    el-mechanic and Soundork like this.
  3. frahengeo
    frahengeo AK Subscriber Subscriber
    783
    Massachusetts
    Thanks for sharing.
    What are your thoughts when comparing the two units. Not familiar with the 90ES, but 10ES is a unit that is still highly sought after, and appears to have a slight edge in build.
    Power comparison? Weight?
    Ds2000 likes this.
  4. yotems
    632
    gx10 is heavier, quicker, stronger, and slightly more detailed
    gx90 while sounding very similar to the gx10 is a bit "creamier" of a sound.
    gx90 is still no slouch in terms of power, its got some real punch to it when you turn it up but the gx10 is something else. the gx90 is rated at 120 rms per channel into 8 ohms with the gx10 being rated at 150 rms per channel into 8 ohms. from 120 to 150 watts technically wouldnt have much if any an audible difference, might just hurt a little more than before.. but the 10 can still just do more and i cant explain it.
  5. Bostown
    Bostown Low End Audio Enthusiast! Subscriber
    4,514
    Boston MA.
    The GX9ES ( not the 90) may lack the copper chassis and extra 30wpc as the GX10es, but sonically I've never heard any major differences when I owned the two units. - folks pay the premium for GX10es when the 9ES performs at the same level. must be the copper chassis or the pride in owning the top of the line from the series of it's time. Can't go wrong either way I suppose.
    whyaskit likes this.
  6. Audioraven
    Audioraven Active Member
    352
    Coachella Valley
    Those are some sexy nudes, yotems! :rockon:
    yotems likes this.
  7. yotems
    632
    sure you can, you can spend 300 on a gx9 or spend 400 on a 1 of roughly 2000 gx10 that has had 30 years to narrow that number down a bit
    already plunging a significant amount of money in some old ass gear instead of something newer and more practically priced, might as well get the one that will always be worth the most of a damn
    the gx9 used a slightly downsized power supply and slightly different setup with the output transistors and is still rated at actually 130 wpc into 8 ohms
    that reminds me of a gx80 i had for a week or two that was in protect mode when it arrived.. the only difference between it and the gx90 i could find was the color of the transformer, heat sink, and the chassis wasnt copper plated. it used the same output transistors, and the same size power supply. the transformer appeared to be of the same size and i didnt notice any difference in weight nor did i notice any difference in hardware used.
    the gx80 is rated at 110wpc and the gx90 is rated at 120 wpc. im glad the gx80 didnt work though, i got my money back and a couple weeks later got the gx90 for an even better deal and not only does the 90 work, it came with the rosewood side panels:). not to mention it looks better and is the prideful TOTL lol
    the gx9 is a nice piece but to be honest if i werent to buy the gx10 for slightly novelty purposes i think i would have put the same amount of money into an NAD integrated, rotel integrated, or even a rotel stereo receiver
