Here’s what I got at the local computer store:
https://m.newegg.com/products/N82E16835230014
I will go fully through it now that’s she’s show some life, I actually ran it with my ps-x75 and a Steely Dans greatest hits, sounded really nice.
So do I need to change thermal paste? It stayed remarkably cool while running for over an hour.
Cool is good.
Assume that is why Sony lowered the bias voltage on the service bulletin, to cool those V-FETs.
By-the-way, they also ordered a resistor upgrade ... from 1/4 to 1/2 watt.
I would do that.
Likely a critical resistor that kills bias voltage if it fails (though have not looked at schematic).
As for the thermal paste ...
Users only rate it 3/5 to start ...
Then there is the issue of "negligible electrical conductivity" - what does than mean??!!
If it were me, I'd use these:
https://www.mouser.ca/ProductDetail/951-SPK10-006-00-05
They are single use pads. Do not over torque, or you will break through the material.
When Echowars was around here (resident VFET expert), these are what he always recommended.
I have used them in multiple rebuilds,any time I had TO-3 output devices.
They are also very neat, no messy paste all over the place. No clean-up.
If you have a meter, be sure to check the bias voltage, one way or another.
If you chose to lower it, up to you.
But lower voltage means cooler, means longer lasting.
What it does for signal quality, you will have to decide.
