Sony TC-K7ii won’t play
Discussion in 'Tape' started by betamax, Aug 2, 2018.
  1. betamax
    betamax Active Member
    123
    New to me Sony TC-K7II cassette deck. Had a bad belt, which I’ve replaced. It will play, but only for a few seconds and only the left spindle turns, not the right. Also, fast forward and rewind only works for about 5 seconds. What’s going on? Counter turns with fast forward and rewind but not with play
  2. betamax
    123
    I've got it to play, the tire that's supposed to engage with the reel was hanging too far over, lubed up the mechanism and it works now.
    Now the problem is that it won't record, and it will only fast forward to rewind a few seconds. The tape counter works fine.
  3. betamax
    123
    *crickets* This must be a lightly traveled forum.
  4. BOUXY
    BOUXY Super Member
    4,700
    WPG,MB CANADA
    No not really,you just have to wait,maybe take a number?:)
  5. zedex
    zedex Active Member
    346
    BC
    Tire is probably worn out or rock hard among other things.
  6. dshoaf
    10,178
    RIP 1954-2018
    If you're looking for help from some of the 'arm chair bench techs' here at AK, it pays to make it as easy as possible to help you. First up, a link to a service manual is always appreciated. Here's an example.
    Next, tape movement problems are almost always a mechanical problem - not electronic. The later cassette decks, however, used light bulbs for detecting tape and transport movements. Check the linked service manual for them and then see if they're working properly. If the cassette deck was subjected to shipping or other heavy, impactful movement, light bulbs will die.
    Cheers,
    David
