Soundbar questions
Discussion in 'Home Theater & Video' started by Dswankey, Aug 5, 2018.
  1. Dswankey
    Dswankey Super Member
    4,013
    What I'm hoping to achieve with this thread is answers from folks here who currently use a soundbar.
    I do not watch a lot of television when I do it's either a sporting event, documentary, nature show or the occasional series and movie. I think we can all agree that internal speakers of most TV's these day sound terrible. I'm just looking for somewhat better sound and clearer dialogue
    My first question
    If I get one that has the ability to decode 2.0 & 5.1 does the unit itself know to switch between the 2 specific to the programming?
    What is HDMI (ARC)? as opposed to Optical and I hope this doesn't open a can of worms but from experience which would you say is most preferable?
    Do soundbars play well with OTA programming and the accompanying audio signal?
  2. valvenator
    valvenator curious bystander, serious procrastinator
    first: a BUMP:beerchug:
    second: I don't ever remember TV speakers not sounding terrible.
    Well, except for my uncle's all in one console that wasn't all that bad.
  3. kwkshift
    kwkshift Active Member
    104
    Usually, if it's a crappier soundbar, it will downmix to 2.0, no matter what signal it is fed. Nicer ones that have multi-channel ability can play in 3.0, 3.1 (with a matching subwoofer), or even 5.0 - 5.1 (again, with a matching subwoofer).
    Soundbars can go from about $100 for a basic Polk or similar, to $1000+ for something like these:
    https://usa.yamaha.com/products/audio_visual/sound_bar/ysp-5600/index.html
    Or, if you want a real beast that can do Atmos and everything else you can throw at it check out:
    https://us.creative.com/soniccarrier/
    I have demo'd it and it's wild.
    Dswankey likes this.
  4. slimecity
    slimecity Super Member
    3,249
    New Zealand
    There is a home theater section in AK - you may need to move this to get more responses ...
  5. Dswankey
    4,013
    Thanks for the feedback!
    As for the Yamaha and the Atmos great suggestions but I'm not planning on spending a lot of money as I just want to upgrade the sound plus I don't watch enough to warrant the expense. I will say that I won't be going the cheap route either. I'd like to be in the 2 to 4 hundred range
  6. Dswankey
    4,013
    Good call, I did not realize that there was a home theater section
    slimecity likes this.
  7. savatage1973
    6,872
    NW Pennsylvania snow belt
    I'm in your camp as well. I don't watch a lot of TV--news, weather, sports, documentaries and re-runs of ancient shows--not a big movie buff, and the ones that I do like to drag out occasionally are too old to have modern encoding for audio. I WAS an early adopter of HT (5.1) a couple of decades ago, but it just wasn't worth it--running wires everywhere, placing speakers everywhere, and the constant "need" to upgrade to the next best thing--why do you think used AVRs are a dime a dozen?
    I use soundbars with a sub on all of my TVs, and they all fall in the $200-500 price range. They are all wired (no wireless BS), and they do just what I need. They can fill the room with sound, and can simulate/expand an HT effect--I know--they are not a "proper" HT set-up, but CNN is not THAT much better in 9.2 than 2.0.
    And yes--the speakers in most TVs suck--but what do you want out of something that has to work in a 1.5" space? My laptop has "Dolby Advanced Audio by Harman Kardon", but it ain't no stereo, either.
  8. WobblySam
    WobblySam Well-Known Member
    586
    Middle of NC
    Since you rarely watch TV, avoid the expense of a soundbar and turn on your TV's closed captions.
  9. Hyfi
    Hyfi Addicted Member
    5,916
    Bucks County, PA
    I use a ZVOX Sound Base that works great for my bedroom application and has a sub out also.
  10. Dswankey
    4,013
    Seriously? I never said I rarely watch tv and the purpose of the thread in my initial post is to find some answer to the questions posed.
  11. John James
    John James "Bob's your uncle" (Stolen) Subscriber
    8,669
    Piney Flats, Tn.
  12. twiiii
    twiiii Addicted Member
    6,742
    west Texas
    The speakers that came with my Elite Pioneer Plasmas are very acceptable for most tv listening. Yes the bass falls off rapidly starting around 70 HZ, but that's OK.
  13. WobblySam
    586
    Middle of NC
    Clearly I misunderstood your statement.
  14. galactus2
    galactus2 Member
    60
    Virginia
    Your question about ARC is that is an Audio Return Channel. It’s on most of the current TVs and from what I understand, it allows the audio pass-through from a blu ray or DVD player connected by HDMI to the TV. Someone more technical than me can explain it better.
  15. Aspen
    Aspen Active Member
    365
    London, Ontario
    Actually the "return" part means that the audio returns from the TV to your receiver for playback. If you are watching OTA tv or the web via a smart tv your can return the audio so you can play over speakers hooked up to the receiver using one one HDMI cable between the receiver/soundbar and your TV.
    It can be tricky to get to work properly so you may end up getting the audio out of the TV by digital optical/coax or RCA cables. What audio out does your TV support? Most will only support 2.0 out from the TV and maybe or may not be both digital and analog. Figure out what the TV can do then look at soundbars and if they are compatible.
    Pass through is a feature in a receiver that allows you, for example, to watch a cablebox show connected from the cablebox to a receiver then to the TV on your TV without having to turn on the receiver. The signal can passively "pass through" the receiver. Usually only the last source selected on the receiver before powering off can be watched this way.
  16. JoeESP9
    16,962
    Philadelphia PA
    IME just about all TV's will support 5.1 on the digital output when using the TV's internal tuner. When using an external source many only support 2.0 on coax/optical out.
  17. Dswankey
    4,013
    Thanks for the replies, I put the soundbar purchase on the back burner for the time being.
