Well I finally got back on the SC amp I was working on in this thread http://www.audiokarma.org/forums/showthread.php?t=492078&highlight=geode I replaced the Bias transistors with 2n3417 which is listed in the schematic. It had 2n3415. The Darlingtons were also exchanged with new onsemis. NOw I can dial the bias in at 21.6 mv on both channels. Only problem now is the Variportional lights stay on for both channels. The heatsinks don't get hot. After letting it sit idling for about an hour they are slightly warm. The variportional lights staying lit apparently means the amp is stuck on the high voltage rails. Anybody know what can be causing this to happen. Thanks.
