ferninando
Lunatic Member
anyone know the sensisitivity of the sansui SP2700s?
No, the 2700A should be the same sensitivity as the non-A version. Used the same basic drivers as the 2700's but had cost reduced cabinets: no veneer on the baffle; just painted pressboard, flat versus curved grilles, no dispersion lens over the front tweeter, and the top firing tweeters were mounted flat rather than at opposing angles. The woofer was revised to have a paper rather than aluminum dust cap, but was otherwise identical to that used in the 2700.
fun stuff Doug... do you have yours on stands that angle the baffle away from the floor? I was thinking of fashioning my own stand that raised them no more than three inches but angles them up about 20 degrees. Thanksgiving night my brother-in-law and I were listening to Frank Sinatra "live in Paris" on cassette, a cassette I had just opened new from 1994 , LOL . It's for moments like these that we are in this hobby...
Mikefc,
I have them on some stands that came with them. Only about 1 1/2". Haven't raised them any higher or at angles.
New cassette from '94, crazy. Frank Sinatra?.....
My stylus just crashed on me, on my FR4060. Going to finally have to get a new one. Time to upgrade?
Hi Doug, by any chance can you send a pic of the stands that came with them? I'd love to create a match if I can. I've been all over the internet looking for images but no luck. Re: stylus, I just upgraded my cart on the Pro-Ject I have. I got the AT540Ml.... wow . what a bargain
View attachment 1341777 View attachment 1341778 View attachment 1341779
Here are some pics. I mainly have them up off the carpet for protection. Had a water heater break few years ago.
Let me know if you can see them ok.
perfect, thank you. That seems easy to replicate. I have a tip for a fellow owner: the Sansui badge on my grille was never straight either, no matter how many times I adjusted it, it went crooked again. So I took off the grille, turned it face down on a soft surface and then used a nut driver just big enough to cover the circumference of the clasp and pushed down, This tightened the clasp against the grille and secured the logo.
What cartridge do you have Doug? Do you need a stylus? Or maybe just swap the cart? That’s a nice looking TT. If it’s a p-mount, maybe change cartridge?Glad the pics will work for you and good to know on the emblems. Usually they are fine until you start moving the component around. I like to have them straight too! I will just have to tighten it per your suggestion.
Still trying to locate a new stylus for my FR-4060.
Take care,
