Hi...
I have acquired one MC240 & an MX110Z.
They are being restored now.
They were working units.
The 240 has Sylvania 6L6GCs and old Mullard 12AX7 (2), old Telefunken 12AX7 (long, smooth, gray), old 12BH7s (not sure what), old Mullard 12AU7s (2). All tubes are good.
The 110 has a lot of tubes. They are old. Amperex Bugle Boy, Telefunken, Philips, Westinghouse.
All tubes are good.
I am fortunate to have a nice assortment of other brands of good, old 12AX7, 12AU7, tubes.
The units are very nice looking.
They should be excellent spec when I get them back.
I have some passive Linn Keilidh speakers;
SPECIFICATIONS - Introduced: 1992 Type: 2-way Infinite Baffle Loudspeaker Frequency Response: 45Hz-20kHz +/- 3dB (Active) 65Hz-20kHz +/- 3dB (Passive) Input Impedance: 8 Ohms per drive unit (Active) 4 Ohms (Passive) Efficiency: 92dB for 1W at 1m (1kHz) Minimum Amplifier Power: 60W / 4 Ohms Drive Units: 19mm ceramic-domed treble, 2 x 160mm carbon-loaded polypropylene bass/midrange Applications: Single-wired, Bi-wired, Bi-amped, Active Bi-amped, Active Tri-amped Size: W 200mm x D 275 mm x H 825mm Weight: 18kg each.
I know about some AR3a speakers but I have never heard the AR3a.
I would appreciate some advice about speakers for this system.
Thank you for any help.
All tubes are good.
