As some of you may know, I have owned these since new, clear back to 1974. They did spend 30 of their 43 years at my brothers house, but they are with me now till the bitter end. For the most part they sound pretty darn good, although opinions of what constitutes a great sounding speaker is all over the map so I will stick with "pretty darn good". These are still for the most part, getting it done for me enjoyment wise.
There has been an issue that I have been struggling with, that occurs on one of them. I have come to the conclusion it is the LE85 driver and after pulling it apart last time for inspection, I slightly dented the diaphragm due to a brain fart. I had a bronze driver but the powerful magnet pulled one of the screws that got away from my hand into it .. Anyway, having nothing to replace the diaphragm with I put it back together and hoped for the best. To my relief I didn't seem to make things worse but the original issue is still there..
Anyway as to that issue. It has a distortion at what I think is a certain frequency or perhaps a certain combination of frequencies that comes up in certain tracks. Loggins and Messina Pathway to Glory, well there are many others too. It is just enough to bug me, usually for brief moments but it hasn't been enough to do anything about it, till now.
I have ordered new diaphragms for the LE85's. Can't buy the originals from JBL, and their recommended replacements are too rich for my blood, but I have heard good things about Radian's replacement diaphragms. So I ordered a set and plan on just doing them both at once so the sound will match for one, and for the other, well I just think that at 43 years they might just both need a rest!
The new Radian's have, instead of a metal surround, a Mylar one. They claim these can be installed "in the field". Does this mean I can just install it and go or do I need to do the frequency sweeps and tighten the screws based on the sound? I am considering trying to find non magnetic stainless screws to replace the steel screws so that a repeat performance of what happened the last time doesn't happen again.
Another question is the dampening foam in these drivers and what to use for replacements. When I pulled the cap off the the one, it was not turning to crumbs yet, but was sticky to the touch and when compressed would not spring back. I didn't have a replacement so I did a bit of a hack job, I replaced the base of the foam with a thin layer of felt, and glued on a open cell sponge rubber sponge to it. This is the type that is used to wipe up excess grout from a tile job. Does anyone have any other suggestions on this? I still have not received the diaphragms yet. They were $88 a piece plus shipping. Not terribly expensive, but I would hate to have to go back in later as those 20+ pound woofers are a SOB to pull out!
Any input and or advice is much appreciated!
