Spray Painting a Tonearm
Discussion in 'Turntables' started by wushuliu, Jan 29, 2014.
  1. wushuliu
    wushuliu AK Subscriber Subscriber
    1,060
    So I've got this crappy looking AR XA tonearm, really beyond any buffing or elbow grease. Any reason I can't just spray paint it?
  2. Montycat
    Montycat AK Subscriber Subscriber
    17,597
    Vancouver
    I think I would buff, but why not paint? It could get a bit tricky near the ends where the tube inserts into the pivot area as the fit has to be precise but what the heck. You can always strip it if is does not work out. You will need to buff it enough to get a good smooth finish anyway though.
  3. thomo57
    thomo57 AK Subscriber Subscriber
    3,057
    Sydney, Australia
    I don't know if the addition of the paint/ weight would affect the performance but others will chime in on that I'd imagine
  4. johnda
    johnda AK Subscriber Subscriber
    4,924
    Southold, NY
    All you need is for some paint to get into the bearings, that can ruin your day! I think a light buffing is the better way. I have had good luck with buffing using aluminum foil, but haven't tried it on a turntable arm yet.
  5. Stanton681EEES
    Stanton681EEES Addicted Member
    7,300
    NE Ohio
    If your talking about the arm tube, why not cover it in heatshrink tubing. at least you know it won't chip off or scratch.
  6. 12ax7
    12ax7 Super Member
    1,992
    Syracuse
    Why not just replace it with a Technics tube?
    OK, I'll shut up now.
    revox-b77 likes this.
  7. KentTeffeteller
    26,165
    Athens, TN
    And eliminate the hard to find headshell issue to boot. And get it good looking again.
  8. pdm4606
    pdm4606 Super Member
    2,951
    Las Cruces, NM
    spray paint
    I think that as I have found anything to deaden the resonances of a tonearm is advantageous.
    My experiences show deadening is the answer to a lot of tracking problems associated with arm design. Never enough in my book.
    Depending on how much and how heavy the coating is will determine the deadening.
    In other words lowering the resonant frequency.
    Paul
  9. marcmorin
    marcmorin AK Subscriber Subscriber
    9,262
    Nope, no reason you can't, or as mentioned, it can be replaced with a bayonet type tube, or if you wish it to remain "stock", those can be had.
    You have lots of options.
  10. wushuliu
    1,060
    Hmmm, heat shrink seems like a good approach. I may give the spray paint a go just for kicks. Thanks guys.
    Technics tube on an AR XA? Ewww :puke2:...:D
  11. marcmorin
    9,262
  12. wushuliu
    1,060
    KentTeffeteller likes this.
  13. DustyOldPile
    DustyOldPile Vinyl Goddess
    2,482
    Wisconsin
    In the mid-80's, I ended up with an all-black component system...except for this faux-aluminum-look plastic silver Akai cassette deck. I carefully masked everything off and found a nice matte-black spray paint and gave it my best.
    I ended up with a cassette deck that looked like it had been spray painted black.
    My advice is to go with one of the solutions that have been suggested other than paint, or just live with it.
  14. FONSguy
    FONSguy Super Member
    2,656
    Sterling, VA
    Why add mass to the arm? Why not use 480 grit wet dry sandpaper and put that kind of finish on that arm?
  15. marcmorin
    9,262
    That XA arm won't work with the XB table. The arm tube will, but the arm block (boss) is different.
  16. chadbang
    chadbang Well-Known Member
    815
    Far From Home
    I had an old Rek-o-Kut which had the usual rusted pitted chrome going on. I first sanded off the bubble chrome and polished the arm, which looked pretty good, but it also looked a little unfinished. I've been thinking about it for days, I but I decided I couldn't take that raw aluminum look, so I sanded the arm tube an spray painted it with Rustoleum Metal Finish Chrome. Looks FANTASTIC!
    I just did the arm tube and not the base or the rest of the arm. I only had rust on the arm tube, so I masked off as close to the pivot bearings as possible (easy, a little painters tape) and sprayed. Now, it takes practice with spray paint. Go light. You don't want to leave tape lines, so you need to tape off what need to be covered but "blur" the paint touchup by not using the blue tape as a guide, but just a shield. leave the "blend" area open, and use the natural air-brush-like flow of the spray paint to you sort of lightly blend the edge, that way you won't get a "tape edge" it takes practice, but it's not hard. Always to practice runs on cardboard.
    But Rustoleum makes killer paint, and their Metal Finish line of paints is great (and cheap). Their gold is the best around, and this chrome did a great job. I did a lot of research of Chrome paint, don't believe the hype on some of these youtube videos, it's very hard to beat Rustoleum for quality. I bought some really expensive gold paint because someone was touting it on youtube, and it look okay. But when I compared it to a three dollar can of Rustoleum, the Rustoleum killed it for looking geniune. This chrome is really nice and it's almost a perfect match for the Rek-o-kut arm. I can't tell which part was painted and which wasn't. So, yeah, you can certainly spray paint a tonearm, especially a heavier one, the weight difference will be negligible with a single coat of spray paint. And Rustoleum is such good paint, one coat will do it.
  17. chadbang
    815
    Far From Home
    I had rust on both, so I just painted another I got today. The chrome was bubbled up on the top of both of these arms, I sanded and painted. I believe the proper thing to do now is give them a gloss top coat?
    Paint job close up
    Blend area
    If I had some fancy airbrush I probably could have done better, but like I say that quality rustoleum shoots really nicely. Just think of lightly misted. In the old days I was the king of runs. I don't do that anymore.
    I LIKE MUSIC likes this.
  18. MRL_Audio
    MRL_Audio AK Subscriber Subscriber
    6,005
    St. Chuck, MO
    @chadbang - what you've done here is certainly encouraging. Nice work.
  19. Grbluen
    Grbluen AK Subscriber Subscriber
    2,370
    Looks great!
  20. bimasta
    bimasta Super Member
    2,741
    If the parts you're spraying are aluminum, it needs a specific primer to be a durable surface.
