Stands for MacIntosh amps
Discussion in 'McIntosh Audio' started by JerryD99, May 15, 2018.
  1. JerryD99
    JerryD99 Member
    68
    South of Jacksonville Florida
  2. techguy0192
    techguy0192 Keep McIntosh amps carbon fiber free! Subscriber
    1,107
    Pick up some nicely finished butcher blocks. You can use them to put your amps on the floor near the speakers.
    darkblue94 likes this.
  3. John James
    John James "Bob's your uncle" (Stolen) Subscriber
    8,674
    Piney Flats, Tn.
    I sure wouldn't put my 52# amp on a glass shelf rated for 50#! :no:
  4. BillWojo
    BillWojo AK Subscriber Subscriber
    2,833
    Burlington, NJ
    I can't bring myself to put expensive gear on glass shelving. The potential for a disaster is very real and I'm not going to risk it.
    52 pounds on a shelf rated for 50 pounds? Nope!
    I know there is a safety factor built in that rating but still.....
    With a wood shelf if you start getting close to failure it lets you know by sagging, etc. Glass gives you zero warning.
    BillWojo
    motorstereo likes this.
  5. John James
    8,674
    Piney Flats, Tn.
    I think there is an old thread around here somewhere that has pictures of what happened when somebody's glass shelf broke. It wasn't pretty.
    darkblue94 and stereocuuple like this.
  6. Velocityboat
    Velocityboat Super Member
    1,160
    TX
    Place it on bottom shelf with a center support of a wood block, machined cylinder or 4 inch diameter trimmed PVC pipe painted black to pick up excess load. Glass flexes just get floor to bottom of glass height measurement correct.
  7. JerryD99
    JerryD99 Member
    68
    Thanks for all your input, but have decided not to install in rack....If I do end up installing in the rack I have some CWD wood shelving I can place on the glass and then I have a 100 lbs. plus capacity. I tried it but did not like the limited vent space about the amp.
  8. E-Stat
    7,231
      File size:
      57.8 KB
      29
