melofelo
Addicted Member
scored this for a friend who wanted 'something that looks good'
this thing weighs a ton...direct drive with quartz lock and LED readout ..speed adjust + or - 6.8%..auto lift at the end of a record which mechanically resets the lift/lower lever itself to "up"...which was a surprise !
it has one of the heaviest platters i've ever encountered on a direct drive deck... and the turntable feels as if its filled with lead....
also of note is a really quirky tonearm..:scratch2: three metal inserts in the top of the plastic(?) bearing housing ....lock nut type metal counterweight that slides independently of the downforce guage...and the bearing housing itself has some kind of springy suspension when you press down on it..hm..very strange design..:scratch2:
at first i thought the tonearm must be broken as it pivots sideways independently of the vertical bearing to a small degree when you apply a small amount of pressure...yet it feels 'cushioned' and returns to its normal once you release downward pressure..
i suspect that inside that housing is some kind of 'anti resonance device' that aiwa proclaims with a black sticker next to the bearing housing...and even stranger..the arm seems to balance a bit like a uni pivot...
i'm not sure...but it seems more part of the design than a fault...so i decided to reset the downforce..and do some alignment..
the rather humble ortofon cartridge it came with was pretty spot on at two null points..close to baerwald..so i decided to leave it as is..this deck has obviously been cared for..
i gave it a spin and a quick clean...and its a rather sweet sounding deck...the arm swings freely without binding when set to zero downforce... and 0.5 gm of anti skate will return the arm to rest smoothly when it hovers above centre of the record in mid air..so all seemed safe...
delivered it to my friend and gave her a hitachi ha-2 amp,hitachi ft 2l tuner and hitachi de-7 cassette deck i had lying around to make a complete retro system..
needless to say she was very happy with it...
she even went out and bought more records for the first time in many years...
here's a few pics i took before i parted with it...
if you stumble across one of these...its well worth a look...i didn't know aiwa made a decent turntable...but this thing is pretty cool...and very well built...
hope you like the pics...
any info on this deck would be greatly appreciated...i think it was made around 1981...but not sure..
