Robisme
Sansui Enthusiast
After I was done, the right channel didn't work. Switched speaker switch to C/separated and used a patch cable to swap right and left. Right channel works now but not left. So, I put the jumpers back in, switched to B speakers(none connected to B) and started tracing the signal. Everything seemed fine so I switched to A speakers where the speakers are connected and both channels are working. Played it for hours. Let it sit and tried again. Works fine.
I had cleaned the controls previously, and had wiggled them all with no change while the channel was out.
While it was not working I reseated all boards and poked around the wires with no change.
Now, I can wiggle boards, controls, and wires and it never drops the channel.
This happened with phono and aux. only inputs I tried. Rear level pots were cleaned.
My thought is the speaker select switch because it also is the pre to main switch. Cleaned it again.
Or, the tuner select switch. The lever was broken of so it may have taken a hit.
Any thoughts? Also, while it was not working I was able to set bias and DC.
Multi-turns installed. Sub-sonic filters removed. Tons of new transistors that are all proper.
Rob
Rob
