streaming music
Discussion in 'Digital Sources' started by mpribble, Apr 17, 2017.
  1. mpribble
    mpribble Member
    97
    Streaming for android phone to chromecast then to peachtree novapre with toslink . Missing anything as far as
    SQ this way? Using Spotify premium know nothing about rates bits what have ya. Is there a better way of doing this would I get better sound from say computer to preachtree? Sorry if this is stupid question really new to this and just winging it.
  2. Condorsat
    Condorsat Audio Enthusiast
    4,091
    Ohio
    External USB DAC for me .... sounds really good to my ears ... if the album was mastered well.
    Does your Peachtree have USB input?
  3. ldatlof
    ldatlof We are all steak Subscriber
    2,652
    Las Vegas
    I like the way you have it setup now. I don't think adding a computer to replace the CCA will sound any better plus, as Condorsat mentioned, you would need usb to go the DAC unless your computer has a toslink output like some Macs do.
  4. botrytis
    Well, if you go to Tidal or some other streaming services, Chromcast doesn't go past CD quality. If you want high res, you will need to use a USB DAC. Most PC's have Tos-link but that will only get you max 96/24 resolution. A USB DAC can get you even 96/24 or even higher resolutions.
    stevo137 likes this.
  5. LesE
    LesE 110284 Subscriber
    655
    Ontario, Canada
  6. Audiofreak71
    Audiofreak71 Boerboelicious Subscriber
    1,373
    PNW
  7. botrytis
    That is new then, then they came out they didn't.
  8. ldatlof
    2,652
    Las Vegas
    IIRC the 96/24 was a firmware update.
  9. mpribble
    mpribble Member
    97
    Yes this unit has usb port and I think coax also this is a new to me set up trying to get use to it. Haven't played with it long enough to know if it sounds better with internal dac or chromecast dac or with toslink or rca to peachtree. Guess I should set and mess around with this somemore. Thanks guys your great help for a guy like me.
  10. mpribble
    mpribble Member
    97
    So is my chromecast my weakest link here? What would a guy do if he was to take out the chromecast out of chain what could I replace it with to stream from my phone it that's all I have as a streamer any other idea's?
  11. mprince
    mprince AK Subscriber Subscriber
    1,289
    Mooresville, NC
    I don't think your Chromecast is the weak link at all, it is a very versatile little thing. I have two, one was run through a DAC via the toslink connection, the other straight into a little Lepai amp in my garage system. I've been happy with both of them, even though the garage one is the only one currently in use as I took the DAC out of my main system and simplified it a bit.
  12. mpribble
    mpribble Member
    97
    What is this jitter some people talk about? and what does it sound like and how to fix it if you have it?
  13. E.Auer
    E.Auer Super Member
    1,226
    Lobster Pot
  14. +48V
    +48V hi-fi or die
    2,554
    Tega Cay
    Yep. :thumbsup:
    The CCA was introduced in Sept. 2015 and Hi-Res (24/96) support was added just 3 months later in Dec. 2015. So it's "new" as of 16 months ago-- within it's 19 month history. ;)
  15. +48V
    +48V hi-fi or die
    2,554
    Tega Cay
    Play some more! I think your present chain is exponentially more than capable of squeezing out all the quality your present streaming source can deliver.
    At this point, it would be most prudent for you to focus mainly on your stream source to see if you can discern an appreciable difference between Spotify's highest bitrate and say a CD rip and/or Tidal lossless stream.
    Play with a free 30 day trial for Tidal. If you feel there's a big difference, then you can consider/weigh subscribing for $20/mo. Even then, your chain (CCA/Nova pre) will still be most worthy.
  16. stevo137
    stevo137 AK Subscriber Subscriber
    2,154
    There's yur answer.
  17. Audiofreak71
    1,373
    PNW
    That is a partially incorrect statement, chromecast does support 96/24 now, check that link below that statement.
  18. stevo137
    2,154
    Sounds as good as CD to me and I don't care about all of your technical details, my ear is my ear.
  19. Audiofreak71
    1,373
    PNW
    I don't care wither about technical mumbo jumbo as long as it sounds good either, however I think it is good to know and be in formed with what I am listening to.
  20. mpribble
    mpribble Member
    97
    +48V thanks making up some new speaker cables waiting on some parts to finish. Should be done this weekend and I'm going to do free trial of tidal the higher rate one.
