Streaming question
Discussion in 'PCs & Music Servers' started by iramegdal, Oct 10, 2017.
  1. iramegdal
    iramegdal Well-Known Member
    520
    Cherry Hill, NJ
    i have recently decided to try streaming. I have 2 houses. In house one, I have a PC running Windows 10 and a Grace Digital Tuner with a media player in it. I can stream files from my PC to my Grace Digital.
    In house two I also have a PC running Windows 10. I also have a Grace Digital Tuner there and a Grace Digital radio. Both have media players. Both recognize the PC server. However, when I attempt to access files in either, e.g. "Artists" I get an "Empty" message. Any ideas as to what I am doing wrong?
    I am thinking of getting a better digital player than the Grace, but am concerned that I have a streaming problem. Any help in a non-technical manner would be appreciated.
  2. dewdude
    dewdude I fix stuff.
    3,017
    Manassas, VA
    Your files don't have metadata. What format are you attempting to stream?
    E-Stat likes this.
  3. iramegdal
    520
    Cherry Hill, NJ
    Primarily ALAC. Perhaps a few of my files are FLAC.
  4. E-Stat
    E-Stat Addicted Member
    5,648
    Eliminate variables one by one.
    Use free software like Tag & Rename to confirm that the tracks are tagged. Typically, that is performed upon ripping CDs or comes with commercially available downloads in many format.
  5. iramegdal
    520
    Cherry Hill, NJ
    Purchased Chromecast Audio and problem is solved. Great device!
    E.Auer and ldatlof like this.
  6. crackerbuzz
    crackerbuzz Active Member
    149
    Stream TIDAL in flac format via. Cabridge audio DAC in kernel bypass mode. You will never go back to anything else ever again provided you have unlimited data from your ISP!
  7. dewdude
    3,017
    Manassas, VA
    I disagree. I'm not paying $20/month to listen to a bunch of stuff I already have on "local storage" that's sometimes in a higher resolution.
    KrisM likes this.
  8. crackerbuzz
    149
    That's a good point... If you don't want to spend the money then there are other ways.
  9. +48V
    +48V hi-fi or die
    2,761
    Tega Cay
    While possible and at times convenient, why indeed would you pay a streaming service to listen to stuff you already have? The $10 or $20 is to have all you can eat access to the stuff you don't have! :beatnik:
    yockmyer, GChief and chicks like this.
