I am about done working on this amp. Schematic is here:
http://audiokarma.org/forums/index.php?threads/stromberg-carlson-asr-333-filter-cap-values.816278/
It uses individual gain pots, one on each channel, and a dual gang "Master Loudness" pot, which does have loudness compensation built into it. I understand how to use this set up, I have other amps with variable loudness controls, but I think I will want to just remove the loudness compensation and use this as a master gain control. It looks like the loudness compensation consists of a 4700 cap and a 47K resistor (C1 & R1 on one channel, C15 & R23 on the other). I assume I remove the cap, do I also remove or change the value of the resistor, and if so, what value should I use?
Thanks.
Thanks.
