Hugh Mongous
New Member
[EDIT] Added links to uncompressed audio files
When looking for a new stylus I found a lot of discussion about Elliptical vs. Hyper-Elliptical vs. Shibata vs. SAS etc. But no real evidence of the differences between the lot. Especially between cheap round/elliptical styli and the step up to a hyper-elliptical.
So, I decided to make one.
I've compared the 24 euro version of the Jico Elliptical (VN35E) between the 120 euro costing Tonar Hyper-Elliptical (VN35HE).
Stylus pressure, VTA and anti-skating are left exactly the same.
The cheaper Jico really doesn't sound great. There seems to be heavy distortion in the low-mid range and treble doesn't extend as much. Stereo field is also not as defined.
Also, the phase of the recording seems te be inverted on the Jico stylus somehow. Not sure how this is possible since I've literally only changed stylus. I've corrected the phase inversion of these tracks in the video.
I might post the lossless files, if anybody is interested in those.
...and here they are:
http://www.mediafire.com/file/c1b3u2w4nlzkspn/Needle_Test.zip
Gear used:
- Dual 704 with Shure V15-III
- Jico VN35E
- Tonar VN35HE
- Yamaha AX-890
- Edirol (Roland) UA-1ex
Software path:
- Recorded with Ableton Live @ 48k-24bit
- Edited with Premiere Pro
- Limited using iZotope 7 with ± 0.5db gain reduction
- Rendered at 320kbps AAC
Tracks used:
- Todd Terje - Preben Goes To Acapulco (Prins Thomas Remix)
- Montana Sextet - Who needs enemies (with a friend like you?) (club mix)
Gear used:
- Jico VN35E
- Tonar VN35HE
- Yamaha AX-890
Software path:
Tracks used:
