i've been listening for more than a month to my lovely little fisher integrated mono amp (chassis 50, p-p el84, 5y3, 12ax7, 6sc7), and it's been very well-behaved.
this morning, after a weekend and a day of not running it, i turned it on, plugged in my iphone and lit up pandora; this is a usual for me, and it's never caused me any problems except for the occasional static.
this morning, however i noticed two or three loud *pops* (as opposed to the paper-crinkling signal static) after about a half hour of listening, and then a bit later a high-pitched screech that sounded like a cross between a needle dragged across the grooves of a record and the sound tires make on asphalt when their brakes are locked up.
on the latter sound i immediately turned off the fisher, let it rest, then turned it back on. listened to half a song, and the loud *pops* came back a couple of times. i've turned it back off, for now.
tube going bad (which one?)? resistor or cap (coupling or power section)? or is that just a bad signal from the pandora stream?
thanks.
thanks.
