What receiver do you currently have ?. Don’t know if the Yamaha you mentioned is really an upgrade over your current receiver without knowing what it is .I have 2 subs so i need to upgrade,i was offered this for 200.00(which is a good deal i think
Yamaha AV Receiver RX-V673 7.2
any comments...i am running Klipsch hereseys as my center and fronts plus 2 KSW 12s for the subs and KSB 3.1s for the rears
My current is a Pioneer VSX 1018 AH-k...7.1Well yeah he should tell us what he has. But most likely he has a 5.1 something or another?? And the Yammy is a 7.1., so if that is the case it would be an "upgrade" as far as HT goes. Be sure it at least works before you bring it home.
how would i hook my second sub to work because i really like this receiverNot sure why having two subs would require an equipment change, I've used two with equipment from the 70's that were never designed to incorporate a subwoofer.
If this is your current receiver it appears to be a 7.1 from all the info.
View attachment 1311085 View attachment 1311086
so,from the 1 sub output,i could put a Y connector in that and run to both subs without any kind of loss?
Thank you all for the comments...i will try "Y"ing them and see the results.......i suppose i will need a more heavy duty adapter...what do i look for and where would i get one.
Thank you...i already have another good single cable so i "bit the bullet" and ordered a Monster Y cable,maybe 15.00 is too much but i trust the brand.I bought mine at The Source here in Canada. You need nothing special. These work perfectly. If you feel better spending more money, Order some from Blue Jeans cable.
That Pioneer AVR looks like a good one BTY, No need to upgrade unless Dolby Atmos is a priority.
yeah...keeping the Pioneer,and i mostly am using the dual subs for movies and concerts on DVD,but i do occassionally put some music on just to listen to the fronts(Hereseys) and subs.I do have a dedicated audio system with a Sansui AU/TU 717,stacked KG4s and Hereseys on the bottom.Personally I don't care how old or obsolete you think your Pioneer is I would never swap for a Yamaha. We sold both for years and the Pioneer was always better. I didn't look up the specs but unless the Yamaha is at least three times as power full driving all channels simultaneously, and the Pioneer is giving you technical difficulties, I would stick the pioneer. Remember 3 times the power is only 4.8 db louder. The plan of using two subs is not for making the sound louder but to get smoother coverage over a larger listening area in the HT mode. If you are going to dedicate the subs for stereo operation, that's another great choice. If you are trying to do both, you may want a 3rd sub for the HT mode of operation. I don't like a mono sub for stereo speakers the bass always seems compromised. Two subs sampling each connect between the pre-amp and power amp section or connected to the speaker lines feeding the front speakers as a secondary choice is my preferred hook up for stereo. Then the third sub can be connected to the LFE channel.
