Sweet new antenna and a couple of questions
Discussion in 'General Audio Discussion' started by Lucky Pierre, Mar 13, 2018.
  1. Lucky Pierre
    Lucky Pierre AK Subscriber Subscriber
    459
    Maynard, MA
    I have been looking for a cool antenna to replace the simple dipoles I use now. I won this from the bay this weekend.
    Are there any reasons that I cannot connect the antenna to two different tuners (not to be used at the same time, of course)?
    It has been a very long time since I have used an antenna with a selector. What does the selector dial on the front do? It has 6 positions.
    Any idea where I might find a manual or other info on it? There is no model identification that I can find.
    L_P
    Lavane, BigElCat and I LIKE MUSIC like this.
  2. Pioneered
    Pioneered Well-Known Member
    719
  3. 91r100gs
    91r100gs AK Subscriber Subscriber
    18,380
    KC area
    It is a frequency trimmer of sorts. When you listen to a specific frequency of the FM dial it will help null out stronger signal within 4 or 5 Mhz of your desired signal. My modern version of this antenna works well. The selector, if I am listening to 89.3 mhz which I do weekly, does nulls out the strong signal at 90.1 mhz and improves the signal strength on the meter by one, by changing the selector setting. When listening to 101.1 mhz it nicely nulls out strong signals at 102.1 mhz and 98.9 mhz by changing the selector. Mine has about a 50 mile range. I can listen to stations in Lawrence KS from the east side of the Kansas City Metro with good signal strength (3.5). When listening to the station 50 miles away changing the selector can trim the antenna to a setting more appropriate for that frequency and increase the signal strength on my meter. If you split the signal you will be reducing the signal to both tuners. I have several of these antennas for OTA digital TV reception and for use on my tunas. My main tuner is a Pioneer TX-8500II.
    Happy Listening
    Link for modern equivalent https://www.amazon.com/RCA-ANT121Z-Durable-Passive-Antenna/dp/B00009W3E2/ref=sr_1_5?ie=UTF8&qid=1520958960&sr=8-5&keywords=rca+rabbit+ears+antenna
    Pioneered likes this.
  4. Lucky Pierre
    459
    Maynard, MA
  5. Lucky Pierre
    459
    Maynard, MA
    Thanks, 91R!
    91r100gs likes this.
  6. the skipper
    the skipper Amateur Curmudgeon Subscriber
    3,249
    Aggieland
    to paraphrase what 91 said, you CAN hook up a 300 ohm splitter and share this between two tuners but there will be some signal degradation.
    And, as far as the rotary switch goes, don't overthink it. Simply position the arms for the best reception and see which position on the rotary switch gives the best reception. You can use either your ear, the SS meter, or both to determine that.
    You may find this is better than your current dipoles but don't be disheartened if it doesn't. It's basically the same type of antenna. Those simple little wire "T" antennas are better than many people want to give them credit for.
  7. Lucky Pierre
    459
    Maynard, MA
    Thanks everyone.
    I hooked it up to my Sherwood S3000 tuner. Based on the Magic Eye, signal strength is better than with the T dipole antenna. Plus, I am able to pick up (though not clearly) a couple of stations down around 89 that I wasn't able to before.
  8. musichal
    11,903
    Norman OK
    Obviously there are some advantages of the rabbit ear over the wire dipole. Adjustable length arms and the ability to easily rotate (aim) can help a lot, I've found.
  9. Lavane
    8,026
    northern cal.
    I like the old rabbit ears. Since they were used indoors many had interesting designs. That RCA is one of the cooler looking ones.
  10. rkgren1
    rkgren1 Super Member
    1,056
    Yorktown, VA
    I also get consistently better results with rabbit ears than I do with the dipoles.
  11. toxcrusadr
    toxcrusadr Omelette au Fromage Subscriber
    34,543
    Central Missouri
    You might want to see if you can get inside that thing and make sure all the connections are clean and not corroded. Could help the signal strength.
  12. Lucky Pierre
    459
    Maynard, MA
    Sure can! I plan on giving it a good cleaning and replacing the flat dipole wire with something longer.
