loweran
Super Member
All, I am waiting on the arrival of an SX-1000TW. It is not in a working state but looks to power on without blowing fuses. I am not planning on touching the tuner at this point.
One question I have is are there viable replacement for the VR pots in the unit. It has a pair of 300 Ohm and 30K Ohm pots. I have not added outputs since I want to test what is in it first.
I built this list from the recap document found here. I had to modify two caps since they are obsolete. I replaced:
667-ECQ-V1H474JL .47uF 50v with MKS2B034701B00KO00
647-UKL1H010KDDANA 1uF 50v with 647-UKW1H010MDD1TD
Here is what I have so far:
Head Amp Unit (W15-089)
W15-089: C101: 10uF 10v CEA: 647-UPW1E100MDD 10uF 25v
W15-089: C102: 10uF 10v CEA: 647-UPW1E100MDD 10uF 25v
W15-089: C105: 10uF 10v CEA: 647-UPW1E100MDD 10uF 25v
W15-089: C106: 10uF 10v CEA: 647-UPW1E100MDD 10uF 25v
W15-089: C109: 100uF 25v CEA: 647-UPW1E101MED 100uF 25v
W15-089: C110: 100uF 25v CEA: 647-UPW1E101MED 100uF 25v
W15-089: C111: 100uF 3v CEA: 647-UPW1A101MDD6 100uF 10v
W15-089: C112: 100uF 3v CEA: 647-UPW1A101MDD6 100uF 10v
W15-089: C113: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
W15-089: C114: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
W15-089: Q101: 2SC458LG : 2SC1845
W15-089: Q102: 2SC458LG : 2SC1845
W15-089: Q103: 2SC458LG : 2SC1845
W15-089: Q104: 2SC458LG : 2SC1845
Control Amp Unit (W15-090)
W15-090: C1: .47uF 25v CSSA: MKS2B034701B00KO00 .47uF 50v
W15-090: C2: .47uF 25v CSSA: MKS2B034701B00KO00 .47uF 50v
W15-090: C5: 1uF 16v CSSA: 647-UKW1H010MDD1TD 1uF 50v
W15-090: C6: 1uF 16v CSSA: 647-UKW1H010MDD1TD 1uF 50v
W15-090: C7: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
W15-090: C8: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
W15-090: C13: 47uF 25v CEA: 647-UPW1V470MED 47uF 35v
W15-090: C14: 47uF 25v CEA: 647-UPW1V470MED 47uF 35v
W15-090: C15: 33uF 6.3v CEA: 647-UPW1A330MDD6 33uF 10v
W15-090: C16: 33uF 6.3v CEA: 647-UPW1A330MDD6 33uF 10v
W15-090: C17: 3.3uF 25v CSSA: 647-UKL1H3R3KDDANA 3.3uF 50v
W15-090: C18: 3.3uF 25v CSSA: 647-UKL1H3R3KDDANA 3.3uF 50v
W15-090: Q801: 2SC458LG : 2SC1845
W15-090: Q802: 2SC458LG : 2SC1845
W15-090: Q805: 2SC458LG : 2SC1845
W15-090: Q806: 2SC458LG : 2SC1845
Main Amp Unit (W15-091)
W15-091: C801: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
W15-091: C802: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
W15-091: C803: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
W15-091: C804: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
W15-091: C807: 4.7uF 25v NP: 647-UES1V4R7MDM 4.7uF 35v
W15-091: C808: 4.7uF 25v NP: 647-UES1V4R7MDM 4.7uF 35v
W15-091: C809: 47uF 25v CEA: 647-UPW1V470MED 47uF 35v
W15-091: C810: 47uF 25v CEA: 647-UPW1V470MED 47uF 35v
W15-091: C813: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
W15-091: C814: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
W15-091: C817: 100uF 6.3v CEA: 647-UPW1A101MDD6 100uF 10v
W15-091: C818: 100uF 6.3v CEA: 647-UPW1A101MDD6 100uF 10v
W15-091: C821: .47uF 50v CSSA: MKS2B034701B00KO00 .47uF 50v
W15-091: C822: .47uF 50v CSSA: MKS2B034701B00KO00 .47uF 50
Power Supply Unit (W16-010)
W16-010: C901: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
W16-010: C902: 10uF 50v CEA: 647-UPW1H100MDD 10uF 50v
W16-010: C903: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
W16-010: C904: 220uF 50v CEA: 647-UPW1H221MPD 220uF 50v
W16-010: C905: 220uF 50v CEA: 647-UPW1H221MPD 220uF 50v
W16-010: C906: 220uF 16v CEA: 647-UPW1E221MPD 220uF 25v
