Before you place any orders take a few images of the PS and Driver boards.
Lets see where it falls in the sx-1010 lineage.
Pioneer SX-1010 recap list
This is "mattsd" list that I use:
Thank you Matt and MTF
Notes:
This list has the 5 %, 63v, WIMA films listed/incorporated, ECQ's are no longer available.
Some E-caps my require a voltage increase up if unavailable.
The cap height on the PS is most critical as the head room between the bottom cover is at issue.
Muting Assembly (AWM-039-A)
AWM-039-A: C1: .47uF 50v CEA: 505-MKS2C034701CJSSD .47uF 50v
AWM-039-A: C2: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
Equalizer Amp Assembly (AWF-013-0) (Q1 & Q3 and Q2 & Q4 should ideally be gain matched, this is optional though)
AWF-013-0: C1: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C2: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C5: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C6: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C9: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C10: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C11: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C12: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C19: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C20: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C21: 220uF 16v CEANL: 647-UKL1C221KPDANA 220uF 16v
Q1: 2SA725: 512-KSA992FBU
Q2: 2SA725: 512-KSA992FBU
Q3: 2SA725: 512-KSA992FBU
Q4: 2SA725: 512-KSA992FBU
Q5: 2SC1313: 512-KSC1845FTA
Q6: 2SC1313: 512-KSC1845FTA
Q7: 2SC1313: 512-KSC1845FTA
Q8: 2SC1313: 512-KSC1845FTA
Control Amp Assembly (AWG-027-0) (Check C49-52, the A version of this board has them as 100uF 16v CEA instead of 47uF 16v CEA like the manual states)
AWG-027-0: C1: .33uF 25v: CSSA: 505-MKS20.33/63/5 .33uF 63v
AWG-027-0: C2: .33uF 25v: CSSA: 505-MKS20.33/63/5 .33uF 63v
AWG-027-0: C7: 100uF 10v CEA: 667-EEU-FM1E101 100uF 25v
AWG-027-0: C8: 100uF 10v CEA: 667-EEU-FM1E101 100uF 25v
AWG-027-0: C13: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C14: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C15: 4.7uF 50v CEA: 667-EEU-FC1H4R7 4.7uF 50v
AWG-027-0: C16: 4.7uF 50v CEA: 667-EEU-FC1H4R7 4.7uF 50v
AWG-027-0: C23: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C24: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C25: 10uF 16v CEA: 667-EEU-FC1H100L 10uF 50v
AWG-027-0: C26: 10uF 16v CEA: 667-EEU-FC1H100L 10uF 50v
AWG-027-0: C29: 100uF 10v CEA: 667-EEU-FM1E101 100uF 25v
AWG-027-0: C30: 100uF 10v CEA: 667-EEU-FM1E101 100uF 25v
AWG-027-0: C31: 4.7uF 50v CEA: 667-EEU-FC1H4R7 4.7uF 50v
AWG-027-0: C32: 4.7uF 50v CEA: 667-EEU-FC1H4R7 4.7uF 50v
AWG-027-0: C39: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C40: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C41: 10uF 16v CEA: 667-EEU-FC1H100L 10uF 50v
AWG-027-0: C42: 10uF 16v CEA: 667-EEU-FC1H100L 10uF 50v
AWG-027-0: C45: 100uF 10v CEA: 667-EEU-FM1E101 100uF 25v
AWG-027-0: C46: 100uF 10v CEA: 667-EEU-FM1E101 100uF 25v
AWG-027-0: C47: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C48: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C49: 47uF 16v CEA or 100uF 16v CEA: 667-EEU-FM1E101 100uF 25v or 667-EEU-FM1E470 47uF 25v
AWG-027-0: C50: 47uF 16v CEA or 100uF 16v CEA: 667-EEU-FM1E101 100uF 25v or 667-EEU-FM1E470 47uF 25v
AWG-027-0: C51: 47uF 16v CEA or 100uF 16v CEA: 667-EEU-FM1E101 100uF 25v or 667-EEU-FM1E470 47uF 25v
AWG-027-0: C52: 47uF 16v CEA or 100uF 16v CEA: 667-EEU-FM1E101 100uF 25v or 667-EEU-FM1E470 47uF 25v
Q3: 2SC1313: 512-KSC1845FTA
Q4: 2SC1313: 512-KSC1845FTA
Power Amp Assembly (AWH-032-0) (Times two) (Check board number, the D version does not have the 1.5uF cap.) (Q1 and Q2 should ideally be gain matched, this is optional though)
AWH-032-0: C1: .68uF 25v CSSA: 505-MKS20.68/63/5 .68uF 50v
AWH-032-0: C2: 1.5uF 25v CSSA: 647-UKL1H1R5MDD1TA 1.5uF 50v (CHECK FOR THIS BEFORE ORDERING!!)
AWH-032-0: C4: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWH-032-0: C8: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
Q1: 2SA726: 512-KSA992FBU
Q2: 2SA726: 512-KSA992FBU
Q3: 2SA726: 512-KSA992FBU
Q5: 2SC1451: 512-KSC3503DSTU
Q6: 2SC1451: 512-KSC3503DSTU
VR1: 2.2K ohm multi offset: 652-3296P-1-202LF 2K ohm 25 turn
VR2: 470 ohm single bias: 652-3386H-1-501LF 500 ohm single turn
Protection Assembly (AWM-062-0)
AWM-062-0: C1: .22uF 10v CSSA: 505-MKS20.22/63/5 .22uF 63v
AWM-062-0: C2: .22uF 10v CSSA: 505-MKS20.22/63/5 .22uF 63v
AWM-062-0: C3: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C4: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C5: 4.7uF 25v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWM-062-0: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
Q1: 2SC869: 512-KSC1845FTA
Q2: 2SC869: 512-KSC1845FTA
Q6: 2SC945: 512-KSC2383YTA
Q7: 2SC1384: 512-KSC2690AYS
1N4004 flyback diode is added between pins 9 (anode +) and 10 (cathode -)
Power Supply Assembly (AWR-054-0) (Stand the new resistors up off the board about a half inch)
AWR-054-0: C8: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C9: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C10: 100uF 63v CEA: 647-UPW2A101MHD 100uF 100v
AWR-054-0: C11: 100uF 63v CEA: 647-UPW2A101MHD 100uF 100v
AWR-054-0: C12: 100uF 35v CEA: 647-UPW1H101MPD 100uF 50v
AWR-054-0: C13: 100uF 35v CEA: 647-UPW1H101MPD 100uF 50v
AWR-054-0: C14: 47uF 50v CEA: 647-UPW1J470MPD 47uF 63v
AWR-054-0: C18: 1000uF 35v CEA: 647-UPW1H102MHD 1000uF 50v
AWR-054-0: C19: 220uF 16v CEA: 647-UPW1V221MPD6 220uF 35v
AWR-054-0: C20: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
AWR-054-0: C21: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
R11: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
R12: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
R20: 3.3 Ohm 1/4 watt: 660-MF1/2DCT52R3R32F 3.32 Ohm 1/2 watt
R21: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
Q1: 2SD313: 863-MJE15032G
Q2: 2SC869: 512-KSC2383YTA
Q3: 2SC869: 512-KSC2383YTA
Q4: 2SB507: 863-MJE15033G
Q5: 2SA628A: 512-KSA1013YBU
Q6: 2SA628A: 512-KSA1013YBU
Q7: 2SD313: 863-MJE15032G
Q8: 2SC1384: 512-KSC2690AYS
Main filter caps, 18000uF 63v, 50mm dia x 90mm high:
(Digi-Key) 565-3331-ND, 18000uF 75v screw terminal 50.80mm dia x 79.38mm high
(Mouser) 661-E36D750N183TC79M, 18000uF 75v screw terminal 50.80mm dia x 79.38mm high
BOM List (with 4 100uF 25v caps for the tone amp, does not include the filter caps or the 1.5uF cap, add if needed)
505-MKS2C034701CJSSD | 1
647-UPW1H470MED | 1
647-UPW2A471MHD | 2
647-UPW1H102MHD | 1
647-UPW1V221MPD6 | 1
647-UPW1C222MHD | 2
647-UPW1E101MED | 1
647-UPW1V4R7MDD | 1
647-UPW1A331MPD | 4
505-MKS20.22/63/5 | 2
647-UPW1E100MDD | 2
505-MKS20.68/63/5 | 2
647-UKL1H2R2KDDANA | 6
647-UKL1C471KPD | 2
647-UKL1E101KPDANA | 4
647-UKL1C221KPDANA | 1
647-UKL1C100MDDANA | 2
505-MKS20.33/63/5 | 2
647-UKL1H4R7KDDANA | 4
647-UPW2A101MHD | 2
647-UPW1J470MPD | 1
647-UPW1H101MPD | 2
667-EEU-FC1H4R7 | 4
667-EEU-FC1H100L | 4
667-EEU-FM1E101 | 10
512-KSC1845FTA | 12
512-KSA992FBU | 12
512-KSC3503DSTU | 4
512-KSA1220AYS | 4
512-KSC2690AYS | 4
512-KSA1013YBU | 2
512-KSC2383YTA | 3
863-MJE15032G | 2
863-MJE15033G | 1
660-MFS1/2DCT52R10R0 | 3
660-MF1/2DCT52R3R32F | 1
652-3296P-1-202LF | 2
652-3386H-1-501LF | 2
