SX-1050 Cap and transistor list
Discussion in 'Pioneer Audio' started by Stevescivic, Aug 11, 2017.
  1. Stevescivic
    Stevescivic Active Member
    198
    Hello fellow AK'ers,
    I am starting the compilation of the SX-1050 recap BOM list and wanted to start a new thread on one from back in 2012 and wanted to confirm with others that the list provided here is the most comprehensive and up to date list available. There are many posts and overlap so it can get a tad confusing. I am using MTF's list. Any thoughts on updates for it? I was going to not recap the tuner as it seems like recapping it would require realigning the FM tuner stage which I am not keen on paying the local shop in town to do.
    Here goes:
    as per MTF from this original thread:
    http://www.audiokarma.org/forums/index.php?threads/sx-1050-needs-recapped-help.483953/
    beware the spacing on the 470uf 100v radial caps on the power supply B board, the diameter may interfere, and the height restriction may also rear it's head.
    This is EVERYTHING, you may not need it all. This inclused about 32 bucks in outputs for a total around 100 bucks, all checked for current mouser.com stock.
    power supply reg-a
    awr-103 c1 220 80 cea x 220 100 647-UPW2A221MHD
    awr-103 c3 47 16 cea x 47 35 647-UPW1V470MED
    awr-103 c6 47 35 cea x 47 35 647-UPW1V470MED
    awr-103 c7 10 35 cea x 10 50 647-UPW1H100MDD
    awr-103 c8 1 50 cea x 1 100 647-UPW2A010MDD
    awr-103 c9 220 80 cea x 220 100 647-UPW2A221MHD
    awr-103 c12 47 16 cea x 47 35 647-UPW1V470MED
    awr-103 c14 47 35 cea x 47 35 647-UPW1V470MED
    awr-103 c15 100 35 cea x 100 35 647-UPW1V101MPD
    awr-103 c16 220 25 cea x 220 25 647-UPW1E221MPD
    awr-103 c17 47 10 cea x 47 35 647-UPW1V470MED
    awr-103 c20 100 25 cea x 100 35 647-UPW1V101MPD
    awr-103 c22 47 10 cea x 47 35 647-UPW1V470MED
    awr-103 c23 2.2 50 cea x 2.2 50 647-UPW1H2R2MDD
    awr-103 c24 220 16 cea x 220 25 647-UPW1E221MPD
    awr-103 q1 2sd313 0 0 0 0 0 512-ksc2073TU
    awr-103 q2 2sc869 0 0 0 0 0 512-KSC2383YTA
    awr-103 q3 2sc869 0 0 0 0 0 512-KSC1845FTA
    awr-103 q4 2sc1318 0 0 0 0 0 512-KSC2690AYS
    awr-103 q5 2sb507 0 0 0 0 0 512-KSA940TU
    awr-103 q6 2sa628 0 0 0 0 0 512-KSA1013YBU
    awr-103 q7 2sa628 0 0 0 0 0 512-KSA992FBU
    awr-103 q8 2sa720 0 0 0 0 0 512-KSA1220AYS
    awr-103 q9 2sd325 0 0 0 0 0 512-ksc2073TU
    awr-103 q10 2sc945 0 0 0 0 0 512-KSC2383YTA
    awr-103 q11 2sc945 0 0 0 0 0 512-KSC1845FTA
    awr-103 q12 2sd325 0 0 0 0 0 512-ksc2073TU
    awr-103 q13 2sc945 0 0 0 0 0 512-KSC2383YTA
    awr-103 d1 wz-140 0 0 0 0 0 512-1N5244B
    awr-103 d2 wz-130 0 0 0 0 0 512-1N5243B
    awr-103 d3 wz-061 0 0 0 0 0 512-1N5234B
    awr-103 d4 wz-061 0 0 0 0 0 512-1N5234B
    awr-103 r1 10 ohms 1 w 0 0 0 0 71-CPF110R000FKE14
    awr-103 r19 10 ohms 2 w 0 0 0 0 594-5083NW10R00J
    awr-103 r20 10 ohms 1/2 w 0 0 0 0 66-RG1/210JTR
    awr-103 r21 10 ohms 2 w 0 0 0 0 594-5083NW10R00J
    surge suppressor
    awx-098 c1 10 63 cea x 10 100 647-UPJ2A100MED
    power supply -b
    awr-104 c9 470 100 ach-038 x 470 100 647-UHE2A471MHD
    awr-104 c10 470 100 ach-038 x 470 100 647-UHE2A471MHD
    awr-104 c11 2200 25 cea x 2200 35 647-UPW1V222MHD
    protection
    awm-090 c1 0.22 25 cssa x 0.22 50 598-DSF050J224
    awm-090 c2 0.22 25 cssa x 0.22 50 598-DSF050J224
    awm-090 c3 470 6 cea x 470 10 647-UPW1A471MPD
    awm-090 c4 470 6 cea x 470 10 647-UPW1A471MPD
    awm-090 c5 2.2 50 cea x 2.2 50 647-UPW1H2R2MDD
    awm-090 c6 47 50 cea x 47 50 647-UPW1H470MED
    awm-090 q1 2sc869 0 0 0 0 0 512-KSC1845FTA
    awm-090 q2 2sc869 0 0 0 0 0 512-KSC1845FTA
    awm-090 q6 2sc945 0 0 0 0 0 512-KSD1616AGBU
    awm-090 q7 2sc1384 0 0 0 0 0 512-KSC2690AYS
    awm-090 d5 eqa01-33r 0 0 0 0 0 512-1N5257B
    power amp
    awh-047 c1 0.68 25 csza x 0.68 50 667-ECQ-V1H684JL
    awh-047 c2 0.68 25 csza x 0.68 50 667-ECQ-V1H684JL
    awh-047 c5 10 16 cea x 10 50 647-UPW1H100MDD
    awh-047 c6 10 16 cea x 10 50 647-UPW1H100MDD
    awh-047 c25 470 6 cea x 470 10 647-UPW1A471MPD
    awh-047 c26 470 6 cea x 470 10 647-UPW1A471MPD
    awh-047 c27 470 6 cea x 470 10 647-UPW1A471MPD
    awh-047 c28 470 6 cea x 470 10 647-UPW1A471MPD
    awh-047 q1 2sa750 0 0 0 0 0 512-KSA992FBU
    awh-047 q2 2sa750 0 0 0 0 0 512-KSA992FBU
    awh-047 q3 2sa750 0 0 0 0 0 512-KSA992FBU
    awh-047 q4 2sa750 0 0 0 0 0 512-KSA992FBU
    awh-047 q5 2sa750 0 0 0 0 0 512-KSA992FBU
    awh-047 q6 2sa750 0 0 0 0 0 512-KSA992FBU
    awh-047 q7 2sc1439 0 0 0 0 0 512-KSC3503dstu
    awh-047 q8 2sc1439 0 0 0 0 0 512-KSC3503dstu
    awh-047 q9 2sc1439 0 0 0 0 0 512-KSC3503dstu
    awh-047 q10 2sc1439 0 0 0 0 0 512-KSC3503dstu
    awh-047 q11 2sa858 0 0 0 0 0 512-KSA1381ESTU
    awh-047 q12 2sa858 0 0 0 0 0 512-KSA1381ESTU
    awh-047 q13 2sa858 0 0 0 0 0 512-KSA1381ESTU
    awh-047 q14 2sa858 0 0 0 0 0 512-KSA1381ESTU
    awh-047 q15 2sc1439 0 0 0 0 0 512-KSC3503dstu
    awh-047 q16 2sc1439 0 0 0 0 0 512-KSC3503dstu
    awh-047 q17 2sb536a 0 0 0 0 0 512-KSA940TU
    awh-047 q18 2sb536a 0 0 0 0 0 512-KSA940TU
    awh-047 q19 2sd381a 0 0 0 0 0 512-KSC2073TU
    awh-047 q20 2sd381a 0 0 0 0 0 512-KSC2073TU
    awh-047 q21 2sa858 0 0 0 0 0 512-KSA1381ESTU
    awh-047 q22 2sa858 0 0 0 0 0 512-KSA1381ESTU
    awh-047 q23 2sb539c 0 0 0 0 0 863-MJ21193G
    awh-047 q24 2sb539c 0 0 0 0 0 863-MJ21193G
    awh-047 q25 2sd287c 0 0 0 0 0 863-MJ21194G
    awh-047 q26 2sd287c 0 0 0 0 0 863-MJ21194G
    awh-047 q27 2sb539c 0 0 0 0 0 863-MJ21193G
    awh-047 q28 2sb539c 0 0 0 0 0 863-MJ21193G
    awh-047 q29 2sd287c 0 0 0 0 0 863-MJ21194G
    awh-047 q30 2sd287c 0 0 0 0 0 863-MJ21194G
    filter amp
    awm-089 c3 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awm-089 c6 10 25 csza x 10 50 647-UKL1H100KDDANA
    awm-089 c9 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awm-089 c12 10 25 csza x 10 50 647-UKL1H100KDDANA
    awm-089 q1 2sc1313 0 0 0 0 0 512-KSC1845FTA
    awm-089 q2 2sc1313 0 0 0 0 0 512-KSC1845FTA
    control amp
    awg-041 c1 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awg-041 c2 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awg-041 c3 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awg-041 c4 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awg-041 c11 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c12 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c13 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c14 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c17 100 16 ach-312 x 100 35 647-UPW1V101MPD
    awg-041 c18 100 16 ach-312 x 100 35 647-UPW1V101MPD
    awg-041 c19 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c20 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c27 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c28 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c29 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c30 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c33 100 10 ach-312 x 100 35 647-UPW1V101MPD
    awg-041 c34 100 10 ach-312 x 100 35 647-UPW1V101MPD
    awg-041 c35 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c36 2.2 25 ceanl x 2.2 50 647-UKL1H2R2KDDANA
    awg-041 c37 100 16 ach-311 x 100 35 647-UPW1V101MPD
    awg-041 c38 100 16 ach-311 x 100 35 647-UPW1V101MPD
    awg-041 c39 100 16 ach-311 x 100 35 647-UPW1V101MPD
    awg-041 c40 100 16 ach-311 x 100 35 647-UPW1V101MPD
    awg-041 c43 10 25 csza x 10 50 647-UKL1H100KDDANA
    awg-041 c44 10 25 csza x 10 50 647-UKL1H100KDDANA
    awg-041 q1 2sc1312 0 0 0 0 0 512-KSC1845FTA
    awg-041 q2 2sc1312 0 0 0 0 0 512-KSC1845FTA
    awg-041 q3 2sc1312 0 0 0 0 0 512-KSC1845FTA
    awg-041 q4 2sc1312 0 0 0 0 0 512-KSC1845FTA
    flat amp
    awg-040 c1 1 25 csza x 1 50 647-UKL1H010KDDANAtd
    awg-040 c2 1 25 csza x 1 50 647-UKL1H010KDDANAtd
    awg-040 c3 1 25 csza x 1 50 647-UKL1H010KDDANAtd
    awg-040 c4 1 25 csza x 1 50 647-UKL1H010KDDANAtd
    awg-040 c5 4.7 25 ceanl x 4.7 25 647-UKL1E4R7KDDANA
    awg-040 c6 4.7 25 ceanl x 4.7 25 647-UKL1E4R7KDDANA
    awg-040 c7 220 35 cea x 220 35 647-UPW1V221MPD
    awg-040 c8 220 35 cea x 220 35 647-UPW1V221MPD
    awg-040 c13 2.2 25 csza x 2.2 50 647-UKL1H2R2KDDANA
    awg-040 c14 2.2 25 csza x 2.2 50 647-UKL1H2R2KDDANA
    awg-040 c15 100 10 ceanl x 100 10 647-UKL1A101KEDANA
    awg-040 c16 100 10 ceanl x 100 10 647-UKL1A101KEDANA
    awg-040 c23 100 10 ceanl x 100 10 647-UKL1A101KEDANA
    awg-040 c24 100 10 ceanl x 100 10 647-UKL1A101KEDANA
    awg-040 c25 220 35 cea x 220 35 647-UPW1V221MPD
    awg-040 c26 220 35 cea x 220 35 647-UPW1V221MPD
    awg-040 q1 2sc1775a 0 0 0 0 0 512-KSC1845FTA
    awg-040 q2 2sc1775a 0 0 0 0 0 512-KSC1845FTA
    awg-040 q3 2sa872a 0 0 0 0 0 512-KSA992FBU
    awg-040 q4 2sa872a 0 0 0 0 0 512-KSA992FBU
    awg-040 q5 2sk30aw 0 0 0 0 0 n/a
    awg-040 q6 2sk30aw 0 0 0 0 0 n/a
    awg-040 q7 2sa725 0 0 0 0 0 512-KSA992FBU
    awg-040 q8 2sa725 0 0 0 0 0 512-KSA992FBU
    equalizer amp
    awf-020 c1 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awf-020 c2 4.7 25 csza x 4.7 25 647-UKL1E4R7KDDANA
    awf-020 c5 220 35 cea x 220 35 647-UPW1V221MPD
    awf-020 c6 220 35 cea x 220 35 647-UPW1V221MPD
    awf-020 c9 220 10 cea x 220 25 647-UPW1E221MPD
    awf-020 c10 220 10 cea x 220 25 647-UPW1E221MPD
    awf-020 c17 33 35 cea x 33 35 647-UPW1V330MDD
    awf-020 c18 33 35 cea x 33 35 647-UPW1V330MDD
    awf-020 c21 10 35 ceanl x 10 50 647-UKL1H100KDDANA
    awf-020 c22 10 35 ceanl x 10 50 647-UKL1H100KDDANA
    awf-020 q1 2sa841s 0 0 0 0 0 512-KSA992FBU
    awf-020 q2 2sa841s 0 0 0 0 0 512-KSA992FBU
    awf-020 q3 2sa841s 0 0 0 0 0 512-KSA992FBU
    awf-020 q4 2sa841s 0 0 0 0 0 512-KSA992FBU
    awf-020 q5 2sc1775a 0 0 0 0 0 512-KSC1845FTA
    awf-020 q6 2sc1775a 0 0 0 0 0 512-KSC1845FTA
    awf-020 q7 2sc1775a 0 0 0 0 0 512-KSC1845FTA
    awf-020 q8 2sc1775a 0 0 0 0 0 512-KSC1845FTA
    awf-020 q9 2sc872a 0 0 0 0 0 512-KSA992FBU
    awf-020 q10 2sc872a 0 0 0 0 0 512-KSA992FBU
    tuner
    awe-067 c35 100 16 cea x 100 35 647-UPW1V101MPD
    awe-067 c36 1 50 cea x 1 100 647-UPW2A010MDD
    awe-067 c38 10 16 ceanl x 10 50 647-UKL1H100KDDANA
    awe-067 c39 47 16 ceanl x 47 25 647-UKL1E470KEDANA
    awe-067 c40 100 16 cea x 100 35 647-UPW1V101MPD
    awe-067 c42 4.7 25 ceanl x 4.7 25 647-UKL1E4R7KDDANA
    awe-067 c43 10 16 ceanl x 10 50 647-UKL1H100KDDANA
    awe-067 c44 10 16 ceanl x 10 50 647-UKL1H100KDDANA
    awe-067 c47 1 25 ceanl x 1 50 647-UKL1H010KDDANAtd
    awe-067 c50 0.22 25 cssa x 0.22 50 598-DSF050J224
    awe-067 c51 1 10 cssa x 1 50 647-UKL1H010KDDANAtd
    awe-067 c52 3.3 10 cssa x 3.3 50 647-UKL1H3R3KDDANA
    awe-067 c54 220 16 cea x 220 25 647-UPW1E221MPD
    awe-067 c59 47 16 cea x 47 35 647-UPW1V470MED
    awe-067 c60 4.7 25 cea x 4.7 50 647-UPW1H4R7MDD
    awe-067 c64 10 16 cea x 10 50 647-UPW1H100MDD
    awe-067 c67 0.1 25 cssa x 0.1 50 598-DSF100J104
    awe-067 c70 1 25 ceanl x 1 50 647-UKL1H010KDDANAtd
    awe-067 c71 0.1 25 cssa x 0.1 50 598-DSF100J104
    awe-067 c72 0.47 50 cea x 0.47 50 598-DSF050J474
    awe-067 q5 2sc1312 0 0 0 0 0 512-KSC1845FTA
  2. rcs16
    rcs16 Super Member
    3,639
    Baldwin, Ontario, Canada
    You need to go through each one and check for availability. Items such as 598-DSF050J224 have been
    [​IMG]Obsolete
    for a while, so you need to find subs for these. So search for subs with these parameters
    Dielectric: Polyester
    Capacitance: 0.22 uF
    Voltage Rating DC: 50 VDC
    Tolerance: 5 %
    Lead Spacing: 5 mm
    Length: 7.3 mm
    Width: 5.5 mm
    Height: 4.8 mm
    Long list of possibilities
    http://ca.mouser.com/Passive-Compon...Z1yx4avuZ1z0vn3tZ1z0vn48Z1z0vn3c&Ns=Pricing|0
  3. Stevescivic
    198
    Okay I will do so once I get myself in front of my laptop.
