sx 1250 and sx1280
Discussion in 'Pioneer Audio' started by howkipfer, Oct 13, 2018.
  1. howkipfer
    howkipfer New Member
    9
    I am new here. I want to use dexoit on my pots and switches. Are they get-able for a novice? I have removed the top and bottom and can't see them. Next is to take off the front. I don't want to do that if I can't get to them there. Can you help? Also, once deoxit is used, can I use "faderlube" on all switches and pots as well, or do you recommend a different product? Thanks.
  2. ivandezande
    ivandezande Super Member
    1,961
    Twin Cities
    You'll have to take off the faceplate, remove the screws on all 5(?) boards to get at them. Just restored a 1250, it's not too bad just be careful. Make sure you pull the speaker selector, filter, and source boards under the flat amp and tone boards and clean them. Fader Lube is great.
    jobrewer1983 likes this.
  3. howkipfer
    9
    Thank you!
    ivandezande likes this.
  4. jobrewer1983
    jobrewer1983 AK Subscriber Subscriber
    11,910
    San Jose, CA
    Yep hit with deox-it than some F100 or F5. The lube actually keeps it nice and smooth.
  5. howkipfer
    9
    Thank you!
