SX-1250 making fluttering sound
Discussion in 'Pioneer Audio' started by G-7500 sansu, Mar 18, 2017.
  1. G-7500 sansu
    G-7500 sansu New Member
    8
    Hey,
    My dad and i just recently had our 2 1250's restored and mine sounds amazing. his on the other hand is making a fluttering sound in the right channel. i tried it on all the channels (A,B,C) on the right and it still flutters. i also tried it with some different speakers and same thing. I was wondering if anyone knows what could be the probable cause.
    Thanks, JJ
  2. petehall347
    petehall347 the brandy coffee man
    24,180
    uk.. the middle bit
    whoever restored it should be the best one to tell you and put it right .
  3. rcs16
    rcs16 Super Member
    3,124
    Baldwin, Ontario, Canada
    For sure, if it was just returned from service, get a hold of them and tell them what's wrong, probably should not wait and take it back ASAP.
    You could isolate the problem to figure out if it is the pre-amp or power amp section. Pull the pre-amp_out/power-amp_in jumpers in the back and use some RCA cables to connect the pre-amp_out of the problem one to the good ones power-amp_in rca jacks. See if the problem returns, if it does then you know it a pre-amp problem or a possible power supply problem. If the problem does not return then try reversing the pre/power amp connections between the 2 units.
  4. WE6C
    WE6C Active Member
    481
    Colfax, Northern California
    Don't do anything that may void your warranty.
