I got lucky and stumbled upon an SX-1280 this week. A contractor that was installing an air compressor at work noticed that we have several big receivers around the building. He said that he had one at home and was going to pitch it because it did not work. He was not even sure if he still had it. A couple days later he showed up with it and asked me to buy it. Done...
I wheeled it into the shop and connected it to the power analyzer for a quick evaluation. It lit up and made power on both sides, tuner wiggled and the stereo light flashed on as I tuned. That was enough.
Time to tear it down...
I have read many threads comparing the 1250 to the 1280. The consensus is that the parts in the 1280 are somehow not as nice and the 1280 is harder to work on. To me it's just different... The parts look to be of the same quality. Getting the boards out for service requires desoldering them, but that takes only a couple of min with a desoldering system.
In about 30 min it was stripped down to this:
The filter caps measured in the 13,000 to 14,000 range.
I can see previous repair work in the tuner. I noticed this gem installed, it should be a PA1001A:
According to the tuner info center this is a Toko KB4437, a known cross for the PA1000A.
Hopefully this week I can find some time to order parts..
