SX-1280 Tuner issues
Discussion in 'Pioneer Audio' started by xratedpez, Mar 27, 2013.
  1. xratedpez
    xratedpez AK Subscriber Subscriber
    1,258
    NY
    Folks, this seems to be the last issue with this nice looking unit.
    No AM or FM reception, antenna or not- regardless of muting switch engaged or not.
    Also, when AM is selected, tuning meter pegs. I've lifted one leg of R66 (180ohms) and it checks good. It appears HA1197 (Hitachi) is responsible for the AM section, and it measures near 17VDC on every leg of the IC.
    Other than swapping IC's out (I certainly don't have any spares!), are there other things to look for on the tuner board? The entire unit has now been recapped, and I don't believe the tuner section was tested prior.
    All other threads I've read with these same issues had a number of BAD IC's that were the culprit. I never get components on eBay, but that might be the only option for these legacy chips!?
  2. bktheking
    bktheking Gitter Done!
    12,823
    Ottawa Ontario
    17vdc on every pin, that sucker has to be shorted.
    I may have a spare.
  3. markthefixer
    21,011
    Bensenville,Illinois
    SEVENTEEN VOLTS? :yikes:
    It's a THIRTEEN volt power feed. Pin 11 on the HA1197...
    Tuner board pin 23 is one of the power feeds. 13.0v maximum, no higher.
    That high of a voltage may eat chips.
    Let's get the voltage back down, then reevaluate. I'd hate to loose the PA1002a chip, those are a real unobtanium part. I was sweating the tuner of the current bench's occupant and that part for the last day or two. Luckily the problem was off board and didn't affect that chip.
    power supply is three transistors and a zener diode.
  4. xratedpez
    1,258
    NY
    Yikes is right. Pin 11 on the HA1197 measures 17.11VDC and pin 23 on the tuner board measures 16.4VDC.
  5. xratedpez
    1,258
    NY
    Mark, you mean pin 23 that goes to the Filter amp board AWM-119? Yep, that measures 16.4V
  6. xratedpez
    1,258
    NY
    Getting 16V on the base of Q7, Power Supply board. Something's still awry fer sure.
  7. bktheking
    12,823
    Ottawa Ontario
    I downloaded the manual from akdatabase and I can barely read it lol.
  8. larryderouin
    21,666
    Glen Burnie Md.
    Try this one here
    That's the hires version. Low Res version is here
    Main site link here
  9. xratedpez
    1,258
    NY
    Looking around for a bad resistor on the P/S board... But typically resistors drift UP when bad, correct?
  10. xratedpez
    1,258
    NY
    Q5, Q6 on P/S board tested bad. Have a replacement for Q5 on hand, but not Q6.
  11. xratedpez
    1,258
    NY
    KSC2310YBU is NLA.
    Any common transistor subs for a suitable replacement?
  12. xratedpez
    1,258
    NY
    Actually, I have a pair of ZTX694B NPN's here... any suggestions there? They seem to match up decently
  13. xratedpez
    1,258
    NY
    Popped the Zetex subs in, and now the tuner P/S values are good-- pin 23 is reading 12.8Vm and the voltages on the transistors are normal. :banana:
    Now to determine what's up with the IC's...
  14. bktheking
    12,823
    Ottawa Ontario
    What's it not doing now?
  15. xratedpez
    1,258
    NY
    Same symptoms unfortunately-- no FM or AM sound, AM pegs the signal meter.
    Trying to find some troubleshooting steps for this type of thing, but no luck so far. I don't think I've ever had to troubleshoot a tuner before believe it or not .
  16. bktheking
    12,823
    Ottawa Ontario
    Did you retest the AM chip pins?
  17. xratedpez
    1,258
    NY
    I did- they all came out to (roughly) 13.2V.
  18. bktheking
    12,823
    Ottawa Ontario
    Pin 10 is supposed to be ground. What about the fm chips?
  19. xratedpez
    1,258
    NY
    FM Chip PA1002 measures 13V-13.3V on most of the pins (as does the AM chip below).
    AM Chip HA1197:
    Pin# / DCV
    1/12.9
    2/12.82
    3/13
    4/13.35
    5/13.35
    6/13.32
    7/12.86
    8/6.24
    9/13.33
    10/ 0.0
    11/13.33
    12/13.35
    13/13.32
    14/13.31
    15/13.33
    16/12.88
  20. bktheking
    12,823
    Ottawa Ontario
    I guess fixing the power supply didn't bring the voltages back down. I'm sure Mark will be along shortly. If you had spare chips to try, well, that would be my first attempt at repairing it.
