sx 5580 / Is this frequency response for real?
Discussion in 'Pioneer Audio' started by lilwing, Feb 12, 2018.
  1. lilwing
    lilwing CAGE FREE AUDIO ZOO Subscriber
    1,201
    Forest Grove, OR
  2. markthefixer
    21,148
    Bensenville,Illinois
    For real? Well, yes...
    Audible - phase relationships contribute to soundstage and clarity - so it's up for debate.
    Easiest way to avoid a question about a deficiency, just don't do the possibly bad thing.
    The 1280 and 1980 go to 80khz.
    Then there's this:
    https://www.hifiengine.com/manual_library/pioneer/sx-d7000.shtml
  3. lilwing
    1,201
    Forest Grove, OR
    Hope I can hear the 7hz! I don't remember seeing a spec that low. (let alone 5hz)
    I doubt I can hear 80-90-100 khz. Too many years on the old ears.
  4. Blue Shadow
    21,933
    SE PA
    That frequency response is not there for you to hear it is there to accomplish what the designers needed to happen in the audible range.
    Kenwood L-07MII Frequency Response is 1Hz to 600kHz. Better clean your ears.
    The Spectral DMC-6 is DC to 6MHz, that is 6000kHz.
    Many power amps go down to DC, direct coupled. Some have switchable capacitors to put into the input section to keep the amp from amplifying DC from the preamp.
  5. mattsd
    mattsd AK Subscriber Subscriber
    1,659
    Cincinnati, Ohio
    Keep in mind though, that's just the power amp, the preamp doesn't go that high. Preamp is spec'd at 10Hz-50KHz for the AUX and Tape +0/-1dB. I took a quick and dirty measurement on the one I just recently recapped here, it went to 44KHz at -1dB. I need to do it again once I get better cables, probably will be able to get the 50KHz spec at -1dB. Through the audio band though it was within +0/-0.3dB across 20-20KHz, pretty damn impressive.
  6. Gazdatronik
    Gazdatronik Super Member
    1,462
    Chattanooga TN via Chicago
    My apt holman amp/preamp combo does a 1hz wave pretty good, I once tested. Cone goes in, cone goes out..at that speed. My computer monitor used to sit on the amp long ago, you could see the colors in the screen shift as the woofers flexed. As far as how high? I don't remember. Maybe 90khz.
  7. LesE
    LesE 110284 Subscriber
    928
    Ontario, Canada
    A while ago, I put together an LTSpice simulation for the SX-1250 amp section just for fun. Using modern OnSemi devices, the predicted FR was 5 to 150 kHz (-1 dB).
