Blue Shadow
Waiting for Vintage Gear from this century
Using the recap list from: http://www.audiokarma.org/forums/in...w-if-there-are-any-known-issues.342822/page-2 I have a question about all the non-caps that are listed.
Here are the parts I currently don't have in stock and I have an order going in soon. The unit works fine. Curious if all of these devices (the diodes, transistors and resistors) should be replaced in a working unit. I know about the need to exorcise the 725s from the unit but are the other devices in need of a refresh now, too? There is nothing listed for the pair of 2SK30s on the flat amp.
power supply reg-a
awr-103 q1 2sd313 0 0 0 0 0 512-ksc2073TU
awr-103 q2 2sc869 0 0 0 0 0 512-KSC2383YTA
awr-103 q4 2sc1318 0 0 0 0 0 512-KSC2690AYS
awr-103 q5 2sb507 0 0 0 0 0 512-KSA940TU
awr-103 q6 2sa628 0 0 0 0 0 512-KSA1013YBU
awr-103 q7 2sa628 0 0 0 0 0 512-KSA992FBU
awr-103 q8 2sa720 0 0 0 0 0 512-KSA1220AYS
awr-103 q9 2sd325 0 0 0 0 0 512-ksc2073TU
awr-103 q10 2sc945 0 0 0 0 0 512-KSC2383YTA
awr-103 q12 2sd325 0 0 0 0 0 512-ksc2073TU
awr-103 q13 2sc945 0 0 0 0 0 512-KSC2383YTA
awr-103 d1 wz-140 0 0 0 0 0 512-1N5244B
awr-103 d2 wz-130 0 0 0 0 0 512-1N5243B
awr-103 d3 wz-061 0 0 0 0 0 512-1N5234B
awr-103 d4 wz-061 0 0 0 0 0 512-1N5234B
awr-103 r1 10 ohms 1 w 0 0 0 0 71-CPF110R000FKE14
awr-103 r19 10 ohms 2 w 0 0 0 0 594-5083NW10R00J
awr-103 r20 10 ohms 1/2 w 0 0 0 0 66-RG1/210JTR
awr-103 r21 10 ohms 2 w 0 0 0 0 594-5083NW10R00J
protection
awm-090 d5 eqa01-33r 0 0 0 0 0 512-1N5257B
power amp
awh-047 q1 2sa750 0 0 0 0 0 512-KSA992FBU
awh-047 q2 2sa750 0 0 0 0 0 512-KSA992FBU
awh-047 q3 2sa750 0 0 0 0 0 512-KSA992FBU
awh-047 q4 2sa750 0 0 0 0 0 512-KSA992FBU
awh-047 q5 2sa750 0 0 0 0 0 512-KSA992FBU
awh-047 q6 2sa750 0 0 0 0 0 512-KSA992FBU
awh-047 q7 2sc1439 0 0 0 0 0 512-KSC3503dstu
awh-047 q8 2sc1439 0 0 0 0 0 512-KSC3503dstu
awh-047 q9 2sc1439 0 0 0 0 0 512-KSC3503dstu
awh-047 q10 2sc1439 0 0 0 0 0 512-KSC3503dstu
awh-047 q11 2sa858 0 0 0 0 0 512-KSA1381ESTU
awh-047 q12 2sa858 0 0 0 0 0 512-KSA1381ESTU
awh-047 q13 2sa858 0 0 0 0 0 512-KSA1381ESTU
awh-047 q14 2sa858 0 0 0 0 0 512-KSA1381ESTU
awh-047 q15 2sc1439 0 0 0 0 0 512-KSC3503dstu
awh-047 q16 2sc1439 0 0 0 0 0 512-KSC3503dstu
awh-047 q17 2sb536a 0 0 0 0 0 512-KSA940TU
awh-047 q18 2sb536a 0 0 0 0 0 512-KSA940TU
awh-047 q19 2sd381a 0 0 0 0 0 512-KSC2073TU
awh-047 q20 2sd381a 0 0 0 0 0 512-KSC2073TU
awh-047 q21 2sa858 0 0 0 0 0 512-KSA1381ESTU
awh-047 q22 2sa858 0 0 0 0 0 512-KSA1381ESTU
output transistors
flat amp
awg-040 q3 2sa872a 0 0 0 0 0 512-KSA992FBU
awg-040 q4 2sa872a 0 0 0 0 0 512-KSA992FBU
awg-040 q5 2sk30aw 0 0 0 0 0 n/a
awg-040 q6 2sk30aw 0 0 0 0 0 n/a
awg-040 q7 2sa725 0 0 0 0 0 512-KSA992FBU
awg-040 q8 2sa725 0 0 0 0 0 512-KSA992FBU
equalizer amp
awf-020 q1 2sa841s 0 0 0 0 0 512-KSA992FBU
awf-020 q2 2sa841s 0 0 0 0 0 512-KSA992FBU
awf-020 q3 2sa841s 0 0 0 0 0 512-KSA992FBU
awf-020 q4 2sa841s 0 0 0 0 0 512-KSA992FBU
awf-020 q9 2sc872a 0 0 0 0 0 512-KSA992FBU
awf-020 q10 2sc872a 0 0 0 0 0 512-KSA992FBU
power supply reg-a
protection
power amp
output transistors
flat amp
equalizer amp
