Fresh recap and replacement of the two 2SA720 transistors on the preamp board and now one channel is out on all sources, and the amp is fine. At zeroed volume, you can hear a little bit out of the dead channel and it goes away as the volume is turned up. Tone controls don't work for either channel strangely.
I have resoldered all joints as it is a double sided board, the two transistors changed are in correctly, and there are no solder bridges or shorted components (which always seems to be my problem).
