merlynski
Curmudgeon Electronicist
I have assembled a BOM for the AF board (GWK-118 only) in the SX-780 for vetting if anyone is willing to look it over. It is not intended to include the STK0050s, the protection relay, front panel controls or the Tuner board parts. I have collected these from multiple posts and old lists on AK. Please look them over and post corrections or additions. Thank you!
ASSY, Capacitance, Voltage, Type, Quantity, Identifier, Mouser number, RPL values, RPL w/Film?, Comment
GWK-118, 0.22, 50, CEA NL, 2, "C227, C228", 647-UKT1HR33MDD, 0.33/50V, y, "RPL Cap Val Does Not Match, Non-Stocked, 2mm lead spacing on rpl cap"
GWK-118, 0.47, 50, CEA, 4, "C401, C402, C403, C404 ", 647-UPM1HR47MDD, 0.47/50V, Y?, "Non-Stocked, 2mm lead spacing on rpl cap"
GWK-118, 1, 50, CEA NL, 2, "C207, C208", 647-UKL1H010KDDANA, 1/50V, y,
GWK-118, 2.2, 50, CEA NL, 8, "C103, C104, C117, C118, C229, C230, C309, C310 ", 647-UKL1H2R2KDDANA, 2.2/50V, y,
GWK-118, 4.7, 25, CEA NL, 2, "C217, C218 ", 647-UPW1E4R7MDD, 4.7/25V, y,
GWK-118, 4.7, 35, CEA, 7, "C201, C202, C324, C325, C326, C327, ", 647-UPW1H4R7MDD, 4.7/50V, (+unmarked position just to the right of C309 and the value was 4.7 uF/35 volt.
GWK-118, 10, 16, CEA, 2, "C318, C405 ", 647-UPW1C100MDD, 10/16V,
GWK-118, 33, 16, CEA, 1, C317, 647-UPW1C330MDD, 33/16V,
GWK-118, 47, 6, CEA, 2, "C213, C214 ", 647-UPW0J470MDD6, 47/6.3V,
GWK-118, 47, 16, CEA, 1, C319 , 647-UPW1C470MDD, 47/16V,
GWK-118, 47, 35, CEA, 2, "C305, C306", 647-UKT1V470MDD, 47/35V,
GWK-118, 47, 50, CEA, 1, C316, 647-UPW1H470MED, 47/50V,
GWK-118, 100, 25, CEA, 4, "C301, C302, C303, C304", 647-UPW1E101MED, 100/25V,
GWK-118, 100, 50, CEA, 2, "C307, C308", 647-UPW1H101MPD, 100/50V,
GWK-118, 220, 6.3, CEA, 1, C406, 647-UPW0J221MED, 220/6.3V,
GWK-118, 220, 16, CEA, 1, C311, 647-UPW1C221MPD, 220/16V,
GWK-118, 220, 63, CEA, 1, C315, 647-UPW1J221MPD6, 220/63V,
GWK-118, 470, 6.3, CEA, 2, "C105, C106", 647-UPW0J471MPD, 470/6.3,
GWK-118, 470, 63, CEA, 1, C314, 647-UPW1J471MHD6, 470/63V,
Transistors
GWK-118, 2sc1775, NPN, 4, "Q5, Q6, Q11, Q12", 512-KSC1845FTA, KSC1845FTA,
GWK-118, 2sc1885, NPN, 2, "Q13, Q14", 512-KSC2383YTA, KSC2383YTA,
GWK-118, 2sa912, NPN, 2, "Q15, Q16", 512-KSA1013YBU, KSA1013YBU,
GWK-118, 2sd325R, NPN, 1, Q19, 512-KSC2073TU, KSC2073TU, 863-MJE15032G
GWK-118, 2sb536L, PNP, 1, Q20, 512-KSA940TU, KSA940TU, 863-MJE15033G
GWK-118, 2SD712, NPN, 1, Q25, 512-KSC2073TU, KSC2073TU, 863-MJE15032G
GWK-118, 2sc1384, NPN, 1, Q26, 512-KSC2690A, KSC2690A, Mouser OOS
GWK-118, 2SC2291, dual NPN, 2 (4), "Q9, Q10", 512-KSC1845FTA, KSC1845TFA, match, bent leads
GWK-118, 2sa979, dual PNP, 2 (4), "Q7, Q8", 512-KSA992FBU, KSA992FBU, match,
Transistors
