SX-828 with wind noise
Discussion in 'Pioneer Audio' started by Matt Mincer, Dec 8, 2018.
  1. Matt Mincer
    Matt Mincer AK Subscriber Subscriber
    141
    Chicago
    Hey All,
    I had posted earlier about this 828 and popping in the low filter. I replaced C31, 32, 37, & 38. That took care of the popping but I was getting a ton of wind noise. I replaced all of the 2SC1312s and all of the 2SA725s but am still getting the same noise. I didn't replace the FETs because I don't have them. B+ is stable and it doesn't matter which input is selected. Also, if I remove the pre in/out jumper, the noise goes away, so I'm pretty sure it's on the front end. The noise is coming from both channels equally and volume and balance don't have any effect on the wind noise. A couple possible clues, the left bass pot is noisy though Deoxed all of the pots. The Audio Muting switch causes a speaker pop a lot like the low filter did before the repair. Finally, when I power the unit there's a bit of speaker pop too. Does anyone one have any ideas? My next step would be to recap the whole board but I don't want to do that if there's a simple fix.
    Thanks
    Matt
  2. john stumpf
    john stumpf AK Subscriber Subscriber
    688
    philippines
    i did one of those a few years back i know about the noises you speak of. sadly im not much help. this is because as it all basically worked as received i went ahead and replaced ALL the transistors with the recommended replacements as i did the re cap. i could hear the ocean surf gradually subside as i rebuilt each board so i dont know WHICH cased WHAT! have you worked on the af board yet? those 2sc458's need to go to as they are on the top ten list of faulty transistors they get replaced with ksc1845. i grew up in evanston,
  3. rcs16
    4,262
    Baldwin, Ontario, Canada
    if it is the jfets, then it is weird that they both go noisy at the same time. But it is possible.
    fader lube f5 for pots,
    I have a QX-9900 same issues, almost certain popping is leaky ecaps. One day, in the mean time, I do not mess with those switches :)
    speaker popping during audio mute is a sign of a possible leaky ecap, should be using low leakage Nichicon UKL.types only.
    speaker pop at power on, I would guess is a DC offset adj issue in the amp, or leaky ecap at the input as well, more UKL or film caps(best) for that position.
    The PS could be going noisy, certain ecaps used for filtering the supplies worn out.
    To be honest once they start acting up, re-cap the whole thing (or at least in sections) and then re-evaluate to see if that fixes the issue, determine then, if you need to go to the next step and replace semis etc. if it is a simple thing to change a old bjt, then go for it while you are in there.
    It is a lot of work, but the new ecaps are so much better than those old ones.
    I use Nichicon UKL or film for CEANL,CSZA positions and UKA or film for signal paths, UPW or other low ESR types for DC filtering.
    Switches are big problem on these old units.Very hard to clean and get that silver oxide tarnish off.
    Some times it is nice to say it is that exact component, but once you have it all apart, you want to change them all so that you do not have to go back in there again, if possible
    Good luck.
    slimecity likes this.
  4. EastPoint
    4,824
    Milwaukee, WI
    I was working on an SA-900 that had a VFET go bad while I was working on it. Suddenly had a ton of hiss/rushing on one channel. Swapped it out and all good now. Weird that you're getting it on both sides. You sure all your pinouts are good on the transistors?
  5. slimecity
    slimecity Super Member
    3,250
    New Zealand
    Agree - if its in both channels - look here.
  6. WE6C
    WE6C Well-Known Member
    536
    Colfax, Northern California
    I once had a noisy transistor cause this type of noise. It sounded like someone left the hose running outside. Probably the same noise you are hearing.
  7. HankM
    HankM New Member
    31
    I rebuild a lot of Pioneer Receivers. It is always the 1313 and 726 transistors that need to be replaced. I just did an 828, my first. Look for the xors on the Tone board as well as the PA's.
