Why, repair it, of course.
Get yourself a service manual first off. Either buy one (recommended), or download it from Hifiengine.
When you have it, look at the schematic. The regulated power supply is AWR-102.
In this order:
You should have:
-13.5V at pin 13
-19V at pin 15
-51V at pin 14.
Check for 13 volts or so across D12, 13 volt zener diode. Replace if bad. Skip if only -19V is missing.
If only the -19 is missing, then:
Replace Q4 and Q6 out of hand. 2SA720 is a part known for recurring failure, and is barely adequate there any way. KSA1013 is a good upgrade for those.
Check R15, 17, 18. Check the whole board for cracked solder joints.
Replace C21, 23.
That should get you back up and running. Afterwards, we can rebuild the whole board.
If other voltages are missing, we'll take that up when you report back.
