sx-950 power supply help
Discussion in 'Pioneer Audio' started by supergilson, Sep 9, 2017.
  1. supergilson
    supergilson Active Member
    244
    Well, I screwed up. I rebuilt my power supply with new caps and transistors. I even had it working.
    I went to test the voltages and damn if I didn't short out pins 13 and 14. Stupid, stupid mistake.
    It immediately blew fuses 2 and 3. Upon replacing them, the voltages on pins 13, 14, and 15 are practically dead.
    I'm no electrical engineer, but I looked at the schematic and figured Q2 Q4 and Q6 are nearby, so I replaced them.
    I currently have -0.3 volts at pin 15, -3.3 volts at pin 14, and -0.008 volts at pin 13. I do have my -62 volts at the collector at Q2. The rest of the board is outputting the correct voltages.
    What else do you think I fried? I suppose I'll start testing resistors and caps in that area. Maybe zeners? Anybody know what zeners those get replaced with?
    thanks in advance
  2. tsd71
    tsd71 RIP Tom Petty Subscriber
    2,608
    New Jersey
    Check the two diodes on that board, one is a 13v and the other a 14v
    ZD1 change to 1N5244B
    ZD2 change to 1N5243B
    supergilson likes this.
  3. zebulon1
    zebulon1 Cleaned up the shop and half finished sets. Subscriber
    4,243
    Las Vegas Nevada
    D2 the 13v zener should do it.
  4. petehall347
    petehall347 the brandy coffee man
    24,479
    uk.. the middle bit
    be sure transistors are right way round first and check zd12 . zd11 will be fine .
  5. supergilson
    244
    That did the trick, but now it's clicking in and out of protection. Do you think sending 50 volts to the protection board hurt something?
    Keep in mind, it's coming off a major rebuild of the power amp.
  6. zebulon1
    4,243
    Las Vegas Nevada
    On the DBT
    Make sure your PS voltages are correct.
    On both amps.
    Check and set the BC Balance and then set the idles to about half the spec.
  7. petehall347
    24,479
    uk.. the middle bit
    yes protect circuit might have taken a hit ..q3 q4 jumps out to me .maybe not though if all all else good :idea:
  8. supergilson
    244
    The 13 volt zener was the problem. Until I could order a new one, I swapped in a 13 volt zener from a sx-1050 parts unit.
    I am getting -46.8 volts at pun 15, but +49.7 at pin 7. Those run to the power amp boards, which are giving me some bad numbers on DC offset. (18 volts)
    Would those voltages mess up the power amp, or should I look elsewhere?
  9. petehall347
    24,479
    uk.. the middle bit
    prob is in power amp .maybe near differentials .
    or is offset bad both sides ?
  10. supergilson
    244
    Both sides acting the same.
    I need to check to see if I made the same mistake on both sides. Outputs are new also. I used mj21195g and mj21196g.
  11. zebulon1
    4,243
    Las Vegas Nevada
    What trimmers did you use?
    Trimmer for the DC Balance?
    Trimmer for the Idles?
    There has been some confusion on the values.
    The wrong resistance trimmer for the DC Balance will cause a rail like condition.
    I can't remember exactly the deal. 500 ohm instead of a 5000 ohm? Or the other way.
    Tsd71 knows.
    The mismatch you see in the regulated is not causing the 18 volts balance issue.
    But:
    One other thing I've done is add in series a 1N4148 to the lower voltage rails zener. This evens the regulated. For some reason the 950 is off slightly. Not sure what the difference if any is. It's just more better.
    Actually the plus side is part of the +13 volt supply. I think it has some influence and why the regulated is off by 4 or 5 volts. It's normal.
  12. tsd71
    2,608
    New Jersey
    VR1 and VR2 are both 10K trimmers, VR3 and VR4 are both 100ohm trimmers
    652-3296W-1-103LF (10K)
    652-3386H-1-101LF (100ohm)
    I hope you are using a dim bulb tester before you blow something else up.
  13. supergilson
    244
    The trimmers are correct. I made that mistake once.
    Considering the voltages wouldn't cause the problem, and it is on both boards, I just need to find what is likely my mistake. For that, I probably don't need to power it up.
    Thanks for the help!
