Tandberg 3011a antenna connector
sixthday
Super Member
Bought this for while. The antenna connector of the tandberg is not a common one. Right now, I just tape the FM wire direct to the pins. Just curious if anyone know the Tandberg's antenna connector Name? Type?
Thanks
I believe you need a PAL female connector for the antenna. You can get a PAL female to coax adapter that should work just fine.
Lissenup is correct. I have a T'berg tuner and use a PAL adapter.
Warning: I have 3 different brands. They are of different lengths. One is so long, and extends the antenna connector so far at the back, that the tuner won't fit on the shelf.
So if you order online, and there are pix, choose the shortest.
