monkboughtlunch
Super Member
What are some great sounding sounding electrolytic capacitor brands/model names (22uf) for replacing the original two tantalum phono capacitors in a vintage Marantz receiver?
From the service manual, C704, C712 22uf/4V. Yes the UKL is the one I meant.
The 22uf/35V is a bit of overkill as the dielectric breakdown voltage or
so called working voltage of 4V is well and truely covered by the replacement
of 35V. If you have the 35V at hand then ok, use it. If you need to place
an order I'd go for 22uf/16V.
If at hand then either of the Elna Silmic's would be fine, again there may/should
be an increase in background noise, these are not low leakage.
I have not used the axials but have read good things about them, both should
be ok.
Again, my preference would be the UKL's although try the silmic's.
I have not used the UPJ's, looking at the datasheet, I would still lean to
UKL and Silmic II's for the better tan delta/esr.
If you are looking for a kick ass phono sound then replacing one cap per
channel is not going to do it. I assume that the rest of the Rx has been
recapped? This would produce noticeable improvement. My general guideline
for caps is,
Main Filter Nichicon KW (for small amps)
General power supply, Nichicon UPW
Bipolar power supply Nichicon UEP
Bipolar audio path, Nichicon UES
General audiopath, Elna Silmic II's (or UKZ)
Power supply rails, Elna Silmic II's (or UKZ)
Low noise, Nichicon UKL
The C704/C712 capacitors are in the signal path: RC high-pass filter for the RIAA feedback. I suggest installing a bipolar type, e.g., Nichicon ES to minimize distortion. Also with the 22µF value and 470 resistor, the F3 cut-off is ~15Hz (somewhat high); you can increase to 47µF (F3=7.2Hz) or 100µF (F3=3.4Hz). Vintage Marantz phono stages often specified a tantalum capacitor in this position; presumably due to the low ESR of tantalum capacitors.
The F3 cut-off is the frequency at which the response is down 3dB. To maintain a flat response down to the lowest desired frequency, the target F3 should be 2 octaves below that desired frequency, e.g., for a flat response at 20Hz, the F3 of the high-pass filer should be 5Hz or lower.
IMO, I don't think the roll-off is intentional per se; it may be due to the physical constraints of the available board space and it would be redundant since the Marantz 18 has a switchable "Lo Filter" on the front panel.Is it possible Marantz engineers used the 22uf to intentionally roll off the lower frequencies in the phono circuit to lessen turntable rumble?
A warped record will produce a low frequency. I'm sure Marantz engineers were smart enough to know that the average consumer didn't want to hear it. I would keep it stock with 22uf and enjoy the genius of Marantz engineering (it's a nice sounding phono). The only change that makes a difference is replacing the noisy transistors with modern equivalents.Is it possible Marantz engineers used the 22uf to intentionally roll off the lower frequencies in the phono circuit to lessen turntable rumble?
